funny gauge issues
antony_e
Basically as above the rev counter needle and the mpg swinger seem to have a mind of theyre own. One minute they'll work great the next the swinger is sat dead middle and the rev counter will either flap about or sit at nothing just flicking.
also whilst im at it is there any way to make the fuel guage more accurate as it will raise and lower as it feels or is this just a regular e30 thing?
cheers guys - ant
cheers guys - ant
I know of faults that occur with the rev counter, and of those that occur with the econometer, but there's no reason why they should occur together. Maybe your problem is with the pins that plug the rev counter into the main circuit board?
Split the two halves of the cluster, remove the rev counter and check the soldering of the pins that push into the main board.
Econometer doesn't usually get affected, but the rev counter can fail if the batteries on the SI board (in the front of the cluster half) go short circuit.
Remove the coding plug from the front right of the cluster, remover the screw that holds the retaining bracket for the board, and slide out the board.
Check whether you have 1.2 volt NiCd batteries or 3.0V lithium batteries. The problems only normally occur on the boards fitted with NiCd batteries.
Place the board in the freezer for fifteen minutes, then measure the voltage across each battery.
While you're in there, (nothing to do with your reported problems) find a rectangular lump on the back of the cluster, almost behind the temp. gauge. This lump contains a large resistor, whose soldered connections (on the print side of the circuit board) often crack. Check these connections, just beside the temp gauge, and resolder if necessary.
Finally, tighten both the small brass nuts on the back of the cluster.
antony_e
Excellent thanks again out of interest if the batteries read nothing or low are they regular swappables?
The batteries are replaceable, but are a special type with tabs on the ends that are soldered in.
If duff NiCd batteries have been left in place too long, they may have leaked, and the board will most likely be unrepairable.
Lithium batteries don't normally need replacing, unless the board has been stored for a long time with the batteries connected.
The lithium and NiCd batteries are NOT interchangeable, although NiMH can be used to replace NiCd ones.
antony_e
Ah cool just noticed i shouldve said its not always the same time but as annoying as they are the fuel bugs me the most as I know there's more in there than the light suggests
Totally forgot about the fuel gauge part of the question!
Gauges don't normally jump around and are accurate. One reason for a jumping gauge can be one of the small brass screws I mentioned above, but there are other possible reasons at the tank end.
Is the problem just jumping, or is the gauge totally inaccurate, such as reading empty when you have half a tank?
What model of E30 do you have?
Ajsingh
My gauge is similar.... It will show half tank... Do a bit of driving, it will drop slowly between half and quater and then come back and then slowly go back towards the quater mark again... This manily happens on motorway driving and is really annoying! I can do 50 miles and in that, it will only move slightly, drive the next day, it will be were it was the night before but then will drop drastically.... This is very frustrating... Iv checked the whole car for leaks of fuel and all is okay.... Any help please brian..
Sorry for hi jacking the thread, but it sounds like our problems are very similar!
E30 Crazy!
On a 62 litre tank, this is probably a problem with one of the level senders. RH one tends to get damaged when the clueless try to remove the fuel pump with the sender in place. Never come across it myself, but I think I've read on here that there's a nut on the bottom of the LH one that can work loose.Ajsingh wrote:My gauge is similar.... It will show half tank... Do a bit of driving, it will drop slowly between half and quater and then come back and then slowly go back towards the quater mark again... This manily happens on motorway driving and is really annoying! I can do 50 miles and in that, it will only move slightly, drive the next day, it will be were it was the night before but then will drop drastically.... This is very frustrating... Iv checked the whole car for leaks of fuel and all is okay.... Any help please brian..
With less than half a tank of fuel, short out each sender in turn, and see if you get a stable, though inaccurate, reading on the gauge, which you should get when the faulty one is shorted.
Ajsingh
Thanks brian... I will give that a shot. Iv never had the pump or sender unit out but some tool before probably has
E30 Crazy!
antony_e
Pretty much as said above I can read it but for example it'll be at half on startup then whilst driving it'll drop to quarter if not lower then turn off leave a while and it'll be back up to half. It just seems to sit wherever on the move,the car is an 87 320 auto converted to manual
62 litre tank fitted with only one sender?
Look underneath the car and see if there is a pipe of around 12mm diameter linking together the bottom of the two halves of the tank.
55 litre tank has this pipe, 62 litre one doesn't.
antony_e
Mine has the pipe
Ajsingh
Im not sure if mine does... Need to check. But if its any help, the car is a 320i coupe on an F reg...
E30 Crazy!
In that case it's a 55 litre tank, and only has one sender, which is part of the fuel pump assembly, and under the oval inspection plate on the RH side of the rear seat pan.
Remove the rear seat pan, pull off the three pin plug on the pump assembly, and connect a 33 ohm resistor between the brown wire and the brown/green wire. This should result in the gauge reading a little over half.
Drive the car like this, and see if the gauge still moves, or stays still.
Moves, then the fault is in the cluster or wiring; stays still, and it's the sender in the tank.
Ajsingh
My build spec sheet says additional fuel..... I was told this meant it had a bigger tank, this true?
Bigger tank im guessing a 62litre and the smaller one to be 55litre
E30 Crazy!
I'm fairly sure "additional fuel" means that they put enough petrol in the tank to ensure it had enough to drive off of the transporter when it arrived at the dealers!
Ajsingh
Loll oh right..
E30 Crazy!
