gearbox not engaging!
hmuminovic
Sat Aug 27, 2011 8:08 pm
hi guys,
today i replaced my auto box for another auto unit! my e30 is a 320i. its a non-switchable auto box!
the problem is now, it will only start in park and neutral, which is normal, however when i shift into gears, the engine revs up propa, but i cannot get it to engage with gearbox to then engage to prop shaft!
what could be the problem?
grantorino
Sun Aug 28, 2011 2:06 am
Lack of fluid? Linkage incorrectly or not attached? You bought a second faulty transmission?
1986 325 ES stick shift 137,000 miles, 1973 Mercedes 280C
hmuminovic
Sun Aug 28, 2011 11:49 pm
fluid is deffinelty fine! i cleaned it all out again today, used air compressor and cleaned through rad hoses too, which flushed everythng out!
could it be that the torque converter has slipped of slightly and not engaging witht the shafts? but wot i don't understand is it spins fine with flywheel, but will not go through gears!!!
grantorino
Mon Aug 29, 2011 1:31 am
The torque converter drives a pump that circulates the fluid. When installing an automatic, the torque converter should be pushed fully into the bellhousing while you spin it prior to installation. Then bolt up the trans to the engine, then pull the torque converter forward and attach the bolts to the flywheel.
hmuminovic
Mon Aug 29, 2011 1:48 am
Thats deffinatly been done!!!
But ive had enuff! Time to do da right thing n get a 325 MANUAL into it ;-)
