battery problems
christo
Post Sun Aug 28, 2011 10:59 pm
Hi guys i am looking for help with my 318i cabrio the problem is that the battery goes flat for no knowing reason i drove it 20miles yesterday went shopping and when i went to start it the battery was just flat,now i checked the alteranor and the battery is new so where can the problem be?? cheers christo.
Post Sun Aug 28, 2011 11:20 pm
Charge the battery, and reconnect it with a milliamp meter between the battery negative terminal and the battery earth lead, to see what the quiescent current is, and to confirm this is the problem. Remove fuses one at a time, until you find where the current is going.
Normal quiescent current for an E30 is around 30mA, but varies depending on equipment fitted.
Post Sun Aug 28, 2011 11:25 pm
Lock your car up and look through the window, are your electric window switches lit up still ?
