megasquirt v3.57m map, advice
mongomushroom
Post Sun Aug 28, 2011 10:21 am
Good Morning All
I am looking for a little help with a megasquirt install. Basically when I was feeling a little trigger happy with the internet banking I bought an m20 megasquirt kit with no research into it. It was bought with the intention of using it in an on going turbo project although after some reading into it I have found out that a wideband O2 sensor would be desirable for such an application. I've built an engine consisting of m20b20 bored out to 84mm with m20b25 pistons, head, crankshaft etc which needs run in and I'm wanting to get the MS running on another engine first or possibly use the standard motronic system before I proceed.
I am hoping to install the MS into one of my other 325's within the next few days but a little confirmation of the procedure and what i've got would be nice before I start.
I'll start by explaining what I have to the best of my knowledge. I've got a megasquirt v3.57m(as writtem on the board, v1 or v2?) wired into a motronic case, gm wasted spark coil, harness, throttle position sensor(green, black & red wires, origin unknown), couple of laptop cables and another sensor. This other sensor I think is intake air temp sensor. On the label it is written IATwPiggy and doesn't look like a lamda sensor that i've ever seen although I stand to be corrected.
The gentleman that sold it to me promised to give some information on the kit but didn't bother and is not answering my emails and texts.
I've read into it and it seems to be an easy install. Best guide I found is: http://wiki.diyefi.co.uk/index.php?titl ... Conversion.
If anybody can advise me on what I've got here and can advise on where to get a base map I would be very greatful. I've fitted an uprated fuel pump to the car and might be fitting injectors from my old gti6 depending on compatibility. My mate is taking them over later and I'll check them out. I'll post some pics when I find my camera. Captain Morgans has blessed my with a crap memory and sore head this morning after making me dance around all night in a tiger outfit but i'm sure i'll find it. Any help would be greatly appreciated.
Last edited by mongomushroom on Sun Aug 28, 2011 11:20 am, edited 1 time in total.
mongomushroom
Post Sun Aug 28, 2011 11:14 am
Image megasquirt board
[/img]Image intake air temp sensor?
Image complete kit, best viewed with head sideways to the right
I'm pretty sure thats a intake air temp sensor, O2 sensor not supplied with kit. is it possible to run without o2 sensor? is it possible that the ecu was built without o2 sensor capacity? should I stop fannying around and just fit the kit as it is to see what happens? [/img]
ross2009
Post Sun Aug 28, 2011 4:34 pm
that center pic is infact a iat sensor the ms is already built to take signals from a o2 wideband and ideally would be needed to get it running right with the right maps the wiki link he used i think ms1
what youve got there is ms2 v3.57 ive got ms2 v3 on mine the only differeance is that the the 3.57 is alreadfy surface mounted instead of home built like the rest of them
it looks a clean enough install there is loads and loads of info on these online
http://www.extraefi.co.uk/ theres a starting point phil who does this knows his stuff
http://www.e30tech.com/forum/showthread.php?t=25663 this is a good wiring diagram for a turbo app hope some of this helps
Turbo M20
v8 project 6.0 twin turbo
mongomushroom
Post Sun Aug 28, 2011 6:38 pm
thanks very much for your reply. do you think I could rob a lamda sensor from something in the meantime to install on the naturally aspirated setup and upgrade to a wideband later on. sorry if i'm asking stupid questions here
ross2009
Post Sun Aug 28, 2011 6:43 pm
no you can't coz a normal lambda is a narrow band where as some thing like a innovate is a wideband which is what ms uses :)
Turbo M20
mongomushroom
Post Sun Aug 28, 2011 7:01 pm
ok thanks very much mate. I better get onto ebay then. Will any wideband do? would you say its a safe bet to assume that the MS was set up to take the wideband in the origonal loom lamda circuit?
ross2009
Post Sun Aug 28, 2011 7:19 pm
it will if you wire it that way you can use the original loom I just wired mine straight from the battery with a relay so it's a switched live
then a wire from the wideband controller goes to the ms as a signal
Turbo M20
mongomushroom
Post Sun Aug 28, 2011 7:51 pm
Ok, thanks very much for your help. i'll just take a chance and assume the signal is wired to the original circuit. awesome pics btw. what kind of boost you running?
ross2009
Post Sun Aug 28, 2011 9:33 pm
thanks man
it's not fully on boost yet still running in the new engine
but hopefully about a bar and about 350 bhp ;)
Turbo M20
mongomushroom
Post Mon Aug 29, 2011 9:53 am
its a very similar thing i'm building myself, bored out b20, borgwarner k27 turbo, split pulse manifold. looking to run a bar at first after running in as well to see how it goes. I'm still in the early stages though. engines almost built up. need to get rid of 1 of my other cars before I can tidy up the shell and get it painted. not enough space for my car collection habits. Good luck with the build mate, hope it all goes well for you
ross2009
Post Mon Aug 29, 2011 10:04 am
yeah thanks mate my builds all done I've got it on the Rd now I've put nearly 400 miles on it now all I've gotta do now is swap over to megasquirt I've already made all my harnesses and stuff ms has been all checked so I might aswell go for it at some point just get it running Na for now
just will have to get it mapped and rolling roared properly when I start putting boost down it
if your engine is standard you won't run much more than a bar I'm gonna run mine at 8-10 psi to start with
that should be fun :)
Turbo M20
