2.8 build which head ????
JAFF
hi all , in the process of getting all the bits for my2.8 build ,just wanting to know what the best combination of head to use an 855 /731 and what cam's can be used to uprate them ,and on that note im still after the con rods
JAFF
any one ?????/
toby
885 head
You've seen this? - http://www.e30zone.net/e30zonewiki/inde ... ding_a_2.8
Cam is your choice but around 272/272 is frequently claimed by a few to be the best all round choice. Others like goosiegander have used slightly higher lift ones.
- **BANNED**
Head choice should be ruled by piston selection.
All 2.8's built to date seem to have used 325i pistons/885 head.
Youth is wasted on the young.
rossmc88
looks like you'll just have to buy my lovely refurb'd 855 head
reggid
i would go 885 unless you spend alot of coin to get the 731 to flow like the 885 which requires oversize valves for the 731 as a minimum. A 731 head with the same flow as a 885 usually would have smaller ports for the same flow which keeps the port velocity higher.
E30 325is with M20B31
JAFF
thanks all i know which route im going to take then
i've still got the m50 rods here, exactly the same size as M20 ones, if a touch lighter
JAFF
Simon13 youve got P.M
