rover-2000 wrote:Thanks guys-will look into it-where is the trottle position switch and what does it look like?? I'm just off the Sutton Road in Walsall-near the "Longhorn" pub.
Throttle position switch ( TPS ) is located on the underside of the throttle body - you need to remove the throttle body to get at it ( order a new gasket from BMW first - they're pennies )
if you plan on keeping the car you may find this book invaluable :
It includes an excellent guide on how to refurb the TPS amongst other things.
the author is a regular contributor on this forum.
Use
www.realoem.com to find the correct part numbers for any bits you need
I know the sutton road/longhorn very well - used to live just up the road in Streetly
