Fitting prefacelift front mud flaps?
Jim320i
E30 Zone News / COTM Team
Post Sun Aug 28, 2011 10:15 am
I bought some mudflaps for the chromie a while back, fitted the rears no problem but when I tried to fit the front, I couldnt, so havent bothered with them since. :?
Now I would really like to get them on but not sure how!
On the flaps they have large plug that they screw into which looks as if it goes into the body work, but there is no hole there for it to go in, and I dont really want to be drilling into metal work around there as I know it will end up leading to more rush at a later date.
Anyone ever retrofitted flaps to the chromie and did you encounter the same issue? Any help is appreciated :cool:
hennabm
Post Sun Aug 28, 2011 10:27 am
Jim
I fitted my flaps back when the car was just 4 years old 8O
Looking at them, you should have a long bracket that fixes to the inner wheel arch liner and then at the bottom of that bracket there is a long bolt and spacer that go into the hole that supports the bottom of the inner wheel liner.
The mudflap itself then bolts to the bracket and is secrued on the edge of the wheel arch by a couple of push on clips.
HTH
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
Jim320i
Post Sun Aug 28, 2011 10:31 am
Thanks very much mate.
Its the long bolt you mentioned I was concerned about, when lining the flap up to the car it just looked as if it needed to go into the body work... But I think I need to try again and see how it goes. Hopefully it was just me being impatient!
hennabm
Post Sun Aug 28, 2011 11:40 am
The very bottom of the wheel arch liner should be secured by a short bolt. I think the hole in the liner is more a slot. This is removed and the long bolt and spacer is used to secure the bottom of the flap bracket.
It is a fiddly job to do.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
