any help? trying the get rear axle off but bushes wont budge
iceox
the rear subframe bushes just wont budge. got to the point where i stuck a metal pole up one and started hitting it with the sledge!! wont fooking budge. arms are still on becuase the nuts are welded and need heat! literaly spent 4 hours trying to get them out. everything is undone but they wont budge, they whole axle is hanging off them. actualy dont understand where they are held on becuase the bolts are pushed right up? how they hell are they hanging on!!! any other options?
cheers
cheers
Duke137
Are the bolts actually out (have you twatted them back up inside the car?)
iceox
lol read through that 3 times now. tried every thing it just doesnt want to budge.
is there anyway to smash them out from inside the car?
iceox
they are lose as anything (can tap them with my finger in) should i pull them completely out?E30BeemerLad wrote:Are the bolts actually out (have you twatted them back up inside the car?)
Jim320i
- E30 Zone News / COTM Team
I lost a finger nail when I last attempted this... Back in June... Still havent got it back... Tried to lever it out and slipped, crushing my finger on the inner arch
It hurt...
I now have a very odd looking finger with the tiniest bit of nail still there.
Like Beemerlad said, have you hit the bolts back into the car? If it still doesnt come off, blow torch the bushes away... I still need to do this but just cant be arsed!
Remove the rear seat base and knock the bolts back up inside the car. Then get a long philips head screwdriver or an extension bar and push it in from underneath the centre of the bush and give it a good wiggle about.
iceox
haha yeh tell me about it, wouldnt beleive how many times ive spanked my head, hand, fingers, nails and all other gay things. literaly been at it for ten hours today, really started to get angry by the end, specialy when my dog kept just walking infront of swinging hammers and stuff! had to sit him in the drivers seat and shut the door in the end lol
iceox
i'll take the bolts totally out tomorow and see if that helps. cant believe this job, never had anything this bloody stupid in my lifeE30BeemerLad wrote:Remove the rear seat base and knock the bolts back up inside the car. Then get a long philips head screwdriver or an extension bar and push it in from underneath the centre of the bush and give it a good wiggle about.
There's a hard way to do things, and an easy way.
The easy way for this particular job is to run a hole saw up through the rubber bushes.
Jim320i
Brian, I think I actually love you a little. Lol... The drills coming out tomorrow I think.
^^ this, remove the bolts completely if not there's a chance you may bend them when the beam drops,E30BeemerLad wrote:Remove the rear seat base and knock the bolts back up inside the car. Then get a long philips head screwdriver or an extension bar and push it in from underneath the centre of the bush and give it a good wiggle about.
Ideally two hole saws. One that just fits inside the outer steel liner of the bush, and one that just fits over the ally bush.Jim320i wrote:Brian, I think I actually love you a little. Lol... The drills coming out tomorrow I think.
You still have to get the ally bushes out, but at least you can get at them and see what you're doing.
iceox
tried a smaller hole saw. i'll try find a deeper one tomorow and give it some welly!Brianmoooore wrote:Ideally two hole saws. One that just fits inside the outer steel liner of the bush, and one that just fits over the ally bush.Jim320i wrote:Brian, I think I actually love you a little. Lol... The drills coming out tomorrow I think.
cheers
Needs to be an exceptionally long saw to get right through the bush.
The ones I have aren't quite long enough - they're around 3mm - 4mm short, but levering the beam down easily rips that last little bit.
iceox
yeh mine are about an inch long. if all else fails i'll just pull the fuel tank out and burn the f!ckers. can change the fuel lines and filter while am there toBrianmoooore wrote:Needs to be an exceptionally long saw to get right through the bush.
have you got the beam off the car?
iceox
nope all still on
Put a cushion or something over the top of the bolt hole before you hit the bolt from under the car - this will mean you can hit it as hard as you like without it flying up into the car and smashing a window or damaging anything elsee30topless wrote:^^ this, remove the bolts completely if not there's a chance you may bend them when the beam drops,E30BeemerLad wrote:Remove the rear seat base and knock the bolts back up inside the car. Then get a long philips head screwdriver or an extension bar and push it in from underneath the centre of the bush and give it a good wiggle about.
