Soaking Passenger Footwell?
Adams-Sideways
Post Fri Aug 26, 2011 2:52 pm
As above cant seem to stop this area from getting soaked at the moment with all the rain, the elephant trunk under the bonnet is clear, what other areas should i check?
Adam
Post Fri Aug 26, 2011 2:54 pm
Remove the glovebox and then put your hand up the back where the hinge mounting plate goes and hope you can't push your fingers through the bulkhead where the big rubber grommet is for the main loom feed from the fusebox area.
Also have a look in the passenger wheel well area at the back and hope you can't see any holes
Post Fri Aug 26, 2011 3:00 pm
Sorry adam but its probably this :
Which will need this :
And if its been getting wet for a while possibly this :
:cry:
Duke137
Post Fri Aug 26, 2011 3:08 pm
Adam it could be like this....
Which will need this:
Most E30's are gone / going in this area even if they appear "mint" when you bought it....
Bad times
Post Fri Aug 26, 2011 3:12 pm
And I thought mine was bad :clin:
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Aug 26, 2011 5:04 pm
I'm still fairly sure I win the rust stakes in that area...
craigieeb
Post Fri Aug 26, 2011 5:49 pm
Grrrmachine wrote:I'm still fairly sure I win the rust stakes in that area...
hmmm...........
This could be a winner...??
Duke137
Post Fri Aug 26, 2011 6:18 pm
craig holy shoit! :eek:
I think Topless Henna Red M3 had some rot issue aswell!
Grrrrmachine, that turd is rotten.com/whatthefook :mad:
bmw9818
Post Fri Aug 26, 2011 6:43 pm
Sure it's not your matrix? Check your coolant levels over time see if it drops
Adams-Sideways
Post Fri Aug 26, 2011 7:49 pm
well im really hoping its none of those rusty looking issues :( wont be fun if it is, but im almost sure its not :( I have been losing coolant light comes on about once every 3 weeks more for long journeys. Where should i check and what bits of interior should i take off to check?
Ad
bmw9818
Post Fri Aug 26, 2011 7:58 pm
stick your palm on the carpet if it smells like coolant its the matrix, my ones still leaking havnt got round to actually checking what to do, but yeah least it aint a rust hole!
Post Fri Aug 26, 2011 8:10 pm
Most likely the heater valve has sprung a leak.
Again, removing the glovebox helps with general access, but it is located in the right hand side of the footwell up on top of the transmission tunnel area. A white valve with pipes coming from it. I don't have a pic of one to describe it any better.
You are best off removing your carpet (seats and centre console need to come out) as you'll never get the carpet dry with it remaining in the car as the foam underneath holds loads of liquid and will just help to rot your floor out.
Post Fri Aug 26, 2011 8:12 pm
You only win if you fixed it :wink:
Ferg you ought to get that welded up before the foxes and badgers move in, actually, do you have deer nearby? :D
Duke137
Post Fri Aug 26, 2011 8:23 pm
have welded most of it, but It ain't like yours so I am scared to post pics lol! I might redo some of it because I rushed one bit and I ain't happy with it :o:
Here's one, I got bored of smoothing it out so I zinc primered it with a view to do it another daybut never touched it again!
Might do a bit this weekend if there is enough Argon left in the cylinder
powelly
Post Sat Aug 27, 2011 2:30 pm
Don't panic Mr Mannering!!!! check your heater valve first as has been said above, also check the rubber grommet around the wiper spindle, I have cured a few wet carpets now by replacing this, rain water seeps in here drips down and fills the heater box, the heater box is in 2 halves and the collected water then leaks out and fills your footwells, I first came across this problem on my car a few years ago, I had all the interior out and then one day while it was pissing down with rain I noticed it.
Image Le Mans Classic 2006
Adams-Sideways
Post Sun Aug 28, 2011 10:20 pm
Thanks guys, can someone post a picture of the heater valve so i know where to look, and which grommer is this around the wiper spindle? any pics?
Thanks for the help :)
powelly
Post Mon Aug 29, 2011 8:58 pm
http://www.realoem.com/bmw/showparts.do ... g=61&fg=45
Number 17 or 19, can't remember which, pretty sure it's 19 though.
Adams-Sideways
Post Tue Aug 30, 2011 12:07 am
thanks mate, will check it tommorow
