what is the little yellow wire on the back of my obc for ?
everything works on it apart from the ambient temp, i know there is no sensor, but i can't seem to locate where the sensor should plug in. I've been searching around the RH headlamps, but all i could find was a round 4pin rubber style plug.
and today i spotted a little yellow wire with a square plastic white 1 pin plug on the back of the obc ?
OBC
bastosm3
- **BANNED**
Outside temp sensor plugs into the l/h brake duct.
OBC horn works with the alarm function.
Not sure about the yellow wire,could it be for the stalk control?
Youth is wasted on the young.
White single pole plug on the end of a plain yellow wire near the OBC plug is unused.
bastosm3
thanks.
i can't seem to find the plug ? i'm thinking that the temp sensor loom might be missing/robbed.
is there anyway to trace it from the obc ? i thought if i knew what colours the wires are as they leave the obc, i could trace them and find out where the loom plugs in or what parts of the loom are missing.
Wires to the temp. sensor are blue and brown (which is conveniently the colours you'll find in twin, black, oval mains flex, if you need to make a loom.)
The interior OBC loom joins the under bonnet OBC loom in the glovebox area, and goes through the engine bulkhead via the large rubber grommet behind the glovebox area.
The OBC interior loom ends in two plugs in the glove box area. The wires in one plug are green, green/red, brown and brown/yellow, and the other plug has the brown and blue that you're looking for.
bastosm3
