Got a problem with a 320 auto. When in drive the back of the car moves up and down and when in park or neutral car rocks a little. You can hear the revs go up and down (every half second) but its not showing on the rev counter. I take it this is an idle issue?
Can anybody help?
Unintentional Lowrider
your idle isn't stable/hunting or it's a little too high and the autobox is picking up on this , making the car rock !!
clean out the icv and tps for starters,
P10mike
Thanks, problem just started one day it was ok before. Icv is newish but still cleaned it, tps i will try next, you can hear it clicking but notice there is a bit of oil in the maf/tb pipe and $hitloads of it coming out of the bottom of the tps.
Curr946
Mike I'm sure James has a 320 throttle body sitting its on a manifold that he was stripping the injection loom off
If your wife must learn to drive, don't stand in her way!
P10mike
Cheers for the info Ricky. I'll give the tps a clean and see what happens.
P10mike
Ok cleaned TPS (It was full of oil) and there was no change. A whistling noise can now be heard at idle and it seems to be coming from just under the inlet manifold. Would the inlet manifold gasket failing cause these sort of symtoms?
Exactly what a failed inlet manifold gasket sounds like, but there are other possibilities, such as the cap over the unused stub pipe by the TPS and the pressed in stubs for the brake servo connection.
Get a metre length of garden hose, stick one end in your ear, and move the other end around the inlet side until you locate the whistle.
Have you checked that the TPS now works electrically? A click doesn't prove it works.
P10mike
Thanks Brian. The stub that is capped is ok as for the brake servo ones, i don't know. Havent checked tps electrically will do that at weekend.
One thing thats been noticed is that when the car has been stood overnight and you drive off the first application off the brakes feel as if the servo isnt working but after that they are fine which could be as you say the pressed in stubs for the brake servo?
Or a severe inlet manifold gasket leak meaning not enough vacuum to operate the servo.
P10mike
Heres hoping.Speedtouch wrote:Or a severe inlet manifold gasket leak meaning not enough vacuum to operate the servo.
