...it's hardly worthy of the technical section and it's quite embarrassing but it's starting to piss me off. Is there some trick to getting the kidneys off the bracket? I've tried for a few minutes but the clips don't want to move and I've given up because I know I'll end up breaking it. I need them off ASAP to paint them. Cheers.
Will.
Edit: 330,000 post in the tech section, I know I'm sad.
A bit of a spastic question...
Ranchero
They're not held on by anything- barring rust possibly. Just get a screwdriver and pry 'em off.
Jim320i
- E30 Zone News / COTM Team
Are you talking about the whole unit on the car or just the chrome bits on the grill itself?
Willeh
The chrome surrounds from the kidneys, its off the car at the moment.
Ranchero
Not sure there's a particular method to this. You just need some patience and some sort of tool to tease the little flaps holding the chrome trim in place forward. Without breaking them of course.
You could try threading piece of wire behind the flap in order to gently pull it forward.
polsta
i have a spare damaged kidney grill and tried to do this myself and had the same problem and broke a clip or 2 , but once painted you could easily just glue it back on anyway with glue along the inside of the grill parts
Jim320i
Generally, when you remove these, the clips almost always snap! I managed to get a set off off though and only broke one so they reattached just fine.
Use a small flat screw driver, expect to swear lots and be ready for it to not go back on... If that is the case, glue it back like suggested. Or buy one already painted black, if thats what your doing.
hongkongfuey
- Mad-tango-geezer
submerge the whole lot into hot water(washing up bowl, and prepare to be shouted at by ur missus) small electrical screwdriver, or pick if you have one, when its warm its less likely to break
with cars like mine,
adit
along with almost all other plastic parts, when forced.Jim320i wrote:Generally, when you remove these, the clips almost always snap!
people seem to forget that 20-25 year old plastic does become somewhat brittle over time.
[quote="bss325i"]
Willeh
Already tried this, helped a bit to make it softer but no luck yet. I want them off to paint them because they were painted before but its was all flaky and shite so I scraped it all off and started again to do a proper job. Think I could get away with them staying on?hongkongfuey wrote:submerge the whole lot into hot water(washing up bowl, and prepare to be shouted at by ur missus) small electrical screwdriver, or pick if you have one, when its warm its less likely to break
