Alarm Wiring For mr mooore on someone with the knowledge
cypriot_boy_2k7
Post Thu Aug 18, 2011 9:33 pm
Just got an alarm, just stuck on a few cables.
heres the wiring diagram
if anyone knows the e30 wiring loom cables and position would be great.
Post Thu Aug 18, 2011 10:17 pm
I've posted the connections many times, for the rightclick remote entry systems. A quick 'search' should find it. Almost everything is in the glovebox area.
I hope you aren't under the impression that this'll make your car secure! It would delay me, or any half knowledgeable potential thief for a few seconds at most.
It's biggest downfall is that it doesn't have an independent power source, so that simply cutting the battery earth cable with side cutters shuts it up while you deal with the alarm sounder.
It's second biggest problem is that all that it does to immobilise is break a single circuit, which can simply be bypassed by the use of a piece of wire with two croc. clips, such as I always keep in my glovebox.
cypriot_boy_2k7
Post Thu Aug 18, 2011 10:33 pm
I have been searching, any keywords you recommend
cypriot_boy_2k7
Post Tue Aug 23, 2011 3:03 am
Brian?
