Towing an auto with towbar
e30-unit-soldier
Can towing a 325i auto in neutral gear selected on auto box cause any damage? I need to tow my car using a Aframe.
Topblag
yes according to the owners manual - there's limits to the speed and distance you can tow it.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
e30-unit-soldier
Need to do around 29 miles at 55-60 mph? That the max rated speed for a Aframe.
i have a spare Autobox
you will need it, best to get it recovered on a trailer or transporter or remove the prop
Topblag
Is the problem with towing to do with oil seals or something similar ?e30topless wrote:i have a spare Autobox![]()
cecotto479
- Caution Unreliable Seller
The oil pump doesn't operate in neutral, no fluid being pumped around but everything moving equals dead gearbox/torque convertor.
Take the prop off to road tow it.
Not that I'm condoning the use of an A frame.
1981 E23 735i
an A frame is a waste of time period, death traps IMO
29 miles at 55-60 mph suggests you are doing a bit of motorway? whilst fooking your torque converter and gearbox you are also breaking the law, you could have the ar5e end on the A frame to avoid this but you need to lock the steering and still have clearance for the towcar,
get it on a trailer or recovery truck , 29 miles won't be that expensive..
e30-unit-soldier
Silly thought can I temporarily shaft the car and get the AA to tow it back for me?
If so what?
If so what?
Jim320i
- E30 Zone News / COTM Team
Ring round local recovery companies... 29 miles... My local one charges £1 a mile I think so your looking at £29... For the sake of not having to replace your gearbox, loose your license, die... £30 is worth it.
cecotto479
I doubt they'd do short distances at £1 per mile, but you might get lucky. £75 would be a decent price.
1981 E23 735i
DHFiS
Remove fuse 11. This will prevent power getting to the fuel pump.e30-unit-soldier wrote:Silly thought can I temporarily shaft the car and get the AA to tow it back for me?
If so what?
lamby
aa towed mine but would only do 25 miles at 30 mph,no A frame allowed only soild bar,they have a list of what car,how far etc.even so wouldn,t do more than a few miles aint worth risk
Duke137
Remove the prop, job done.
- **BANNED**
If you can mount an A frame,you can tow a trailer...
And do the job properly!
Youth is wasted on the young.
Jim320i
cecotto479 wrote:I doubt they'd do short distances at £1 per mile, but you might get lucky. £75 would be a decent price.
Seems steep doesnt it? The guy I have used in the past was a random and did it at a £1 a mile and it was only 20 miles or so when I used him... If I was him, I would just ring around, someone out there who must be short on work that will take the business.
