got my roof gutter stole of my sport !
nm1
Mon Aug 22, 2011 7:49 pm
i got the black trim on the roof gutter of my sport stolen on saturday, got a new one today and it doesnt seem to want to fit properly, if any 1 has ever de chromed there car could they give me some advice on fitting this part, thanks in advance
BackPeddler
Mon Aug 22, 2011 7:55 pm
I bought a second hand one and fitted it on my touring last night, nightmare!
Mine was ever so slightly bent from removal, ended up taping it down in 5 places with 2" masking tape and tapping it on with a small very soft sand filled rubber mallet.
When a hammer is your only tool, every problem becomes a nail.
nm1
Mon Aug 22, 2011 7:58 pm
thats what i was doing and then i thought to myself there must be an easier way, think i need a bigger rubber hammer lol
BackPeddler
Mon Aug 22, 2011 8:04 pm
the one i used was small.
As i keep telling the girls i date, the size is not important its the motion winkeye
you need to do glancing blows across the face of the trim, bit difficult when your 1st getting it started and start from one end work across. It wont just pop on you need to work it across and back to the begining, it will gradually go further and further on, as your nearing the end you will need to give it a little tap inward at the bottom.
nm1
Mon Aug 22, 2011 8:07 pm
thanks mate i will give it another go.
harry_p
Mon Aug 22, 2011 8:09 pm
you have to slide them on from the front, do the roof bit forst with the bit that runs down the screen pointing out sideways, then when it's almost all the way back twist it so the bit that runs down the pillar slots over the lip, i then crimped mine a couple of times with some pliars being carefull not to mark it.
cheers,
harry
BackPeddler
Mon Aug 22, 2011 8:12 pm
due to the shape of the corner of the rain gutter i found that impossible without misshaping the trim, maybe thats why you needed to crimp it after?
harry_p
Mon Aug 22, 2011 8:16 pm
it only needed squashing on the bit down the pillar, as that's how the old one came loose and fell off at high speed.
not sure whether theyre clipped or taped from the factory, it took a bit of jiggling, but sits perfectly.
cheers,
harry
BackPeddler
Mon Aug 22, 2011 8:17 pm
either way, a pain in the arse!
Jim320i
E30 Zone News / COTM Team
Mon Aug 22, 2011 8:20 pm
They shouldnt need altering to fit aslong as they aren't damaged.
You need slide it on from the front of the car with the section that goes down at a angle pionting out from the car if that makes sense? It then slides back pretty simply, then you just get you finger tips on the section fitted to the car and roll it downwards.
You might find it doesnt sit in exactly the right position, if not, just pull the down section bit off again and slide it into the right position to get the length sitting perfect.
It should have little gripper things on the down section that hold it into place, although mine lost them so I wedges a bit of plastic behind it and it worked a treat!
Also, get some fairy liquid on there or similiar to help it slide into place. Not sure which zoner recommended this to me before so cant give them the credit for that bit!
Mon Aug 22, 2011 9:03 pm
Never tried to slide them on, I start at the back of the car with the front A pillar section up in the air, push it over the seam working forwards then roll it down to bring the front section onto the A pillar, obviously checking along the length to make sure its going on nicely
nm1
Tue Aug 23, 2011 9:54 am
thanks for all the help guys got it sorted easy when you know how. 8) thanks once again
polsta
Tue Aug 23, 2011 12:05 pm
so how did you do it ? got some sat here thats all been re painted i need to get round to putting on
cant belive someone stole it from your car 8O :?
Green
Tue Aug 23, 2011 12:34 pm
When I replaced mine I just lined it up and clipped it on and had no problems with refitting it :)
nm1
Tue Aug 23, 2011 4:14 pm
i used the rubber hammer method, went on no problem, yeah i cant believe some one would take it off my car, there are dirtbags about,
Green
Tue Aug 23, 2011 4:55 pm
Least you know what car to find it on :roll:
