speedo
pud1
Post Sat Aug 20, 2011 12:02 pm
Mornin all,
Speedo is on the blink. You can run the car for half hour then it starts to blip up and down. My electronics background says heat related, dry joint on the pcb in the cluster etc. Could it be anything else?
**BANNED**
Post Sat Aug 20, 2011 12:12 pm
Most speedo related issues stem from the back of the car...
Speed sensor is mounted on the diff backplate,but first check the wiring to it,and replace as much of the visible wire from the sensor plug into the harness as possible.
Be unusual to have a speedo fault on the cluster board,but not impossible!
Youth is wasted on the young.
pud1
Post Sat Aug 20, 2011 1:44 pm
Soon as I get it back I,ll have a look. I noticed a bit of weeping and dirty oil over the diff case. Think it could be a seal(s) on the way out so its going to kill two birds..
thanks for the info
Post Sat Aug 20, 2011 4:49 pm
Most speedo faults are diff. wire related, but an appreciable percentage are as a result of dry joints on the pins where the speedo daughter board plugs into the main board.
Tapping the top of the dash is the test.
pud1
Post Sun Aug 21, 2011 5:25 pm
Yep. just have to go for the obvious and the simple and degenerate to the complicated and expensive and the inevitable swearing. Its time related. It starts to blip into life after a certain time has gone by. Its probably heating up as the dash cavity heats up and making contact.
polsta
Post Mon Aug 22, 2011 12:57 am
had this myself, finaly got round to having a look/go yesterday, starting with the wire as id had the speedo out
and its like brian says, and said to me.. its that wire, only have to replace the wire from the diff plug to where it joins the other wires comming from above the fuel tank, and that fixes it, i did it with some bullet connections, to just try, and it fixed it, when i get my stereo put in il get the wired soldered and heat shrinked etc
aceifty
Post Mon Aug 22, 2011 4:26 pm
i had the same problem and i changed the Speed sensor and the wire but still had the same problem, i tried a spare speedo and that had fixed it :D
pud1
Post Thu Aug 25, 2011 5:14 pm
Mmm.. Im still thinking heat.
Its smacks of either the speedo housing heating up or the diff doing the same.
Its the same symptoms each time, 10-15mins, it starts to blip then it kicks in and stays working.
I,ll just work thru it from the pulse generator forwards....changing parts at great expense.
Dont you just love classic cars...
