ATF in the gearbox - what grade though ?
clipper
Post Fri Aug 19, 2011 10:51 pm
I had a load of ATF ledt over from when I did mine and my in laws PAS fluids, so I thought I'd use it up by doing a gearbox oil change.
Thing is the ATF bottles say that its SAE10W. Compared to BMW's recommended 80W isn't that like water ?
I've seen doing a search that Daimlerman mentions using ATF 4000, is that a different grade ?
Or should I just stick to 75/80W which I can get from the spares shop tomorrow (in sub-zero temps it can take persuading to selct first when first starting up but never really given any other problem apart from a hideous lay shaft rattle in neutral)
Post Sat Aug 20, 2011 8:42 am
if its manual and selecting ok then keep the 80/90 in it. I'm not sure why people use ATF dextron 2 in the manual boxes but they do. Its what the auto boxes use
**BANNED**
Post Sat Aug 20, 2011 10:00 am
I use ATF to lighten the gearshift when the 'box is cold,'er indoors used to moan about 'heavy gears'.
ATF is,I believe,the BMW reccomendation for ZF 'boxes,E34/E36 on.Certainly,the manual ZF 'box I pulled out of the E34 that donated it's M50 to my touring had a sticker on it saying that ATF should be used.
Been using the stuff for several years,now,no ill effects have been noticed.
Still keep 80/90 gear oil 'in stock',though,for diffs!
Youth is wasted on the young.
clipper
Post Sat Aug 20, 2011 1:51 pm
yeah but I'm not convinced that the SAE10 ATF is suitable. I think I'll go for 80/90 then.
Thanks all.
Post Sat Aug 20, 2011 4:46 pm
AFAIK, in the UK ATF is ATF. Dextron II or III for a gearbox.
Don't think I've ever seen any reference to viscocity on it.
clipper
Post Sat Aug 20, 2011 10:09 pm
Well TBH I've driven myself crazy trying to source exactly the right transmission oils so finally have bought the closest I could get and what most people on various websites recommend....
For the box I have bought a mineral 80W90 / API GL5 (the book says SAE80 / API GL4)
For the diff I have bought an LS80W90 (the book says SAE90 and doesn't seem to distinguish between LSD and standard open diffs).
Tomorrow I'm going to pour 'em in and see what happens (although with over 35º forecast for tomorrow I may just go yo my in-laws swimming pool instead of lying on the tarmac under a car in the open air.......)
**BANNED**
Post Sun Aug 21, 2011 9:52 am
Pool option sounds good...
What is it they say in Spain? Manyana? :o:
clipper
Post Sun Aug 21, 2011 4:26 pm
Opted to sweat it out under the car.... could I get the gearbox filler plug undone ? Could I f*ck...
Only had one stainless 17mm bolt, so I tried putting double nuts on it and a bar over the end of a 17mm ring spanner on the inner nut... snapped the bloody bolt ! :mad:
Tried teasing it loose with a hammer and punch but decided to stop before I destroyed the plug.
Thank god I'd read on here to not drain the oil until the filler plug was out so at least i can still drive the car.
At least I got the diff oil changed, but how the hell am I going to get the gearbox plug out ? No room for a rattle gun in there.... any ideas ?
Post Sun Aug 21, 2011 5:52 pm
The correct tool and a hot gearbox.
