Went to go out today and the car won't start, it's getting fuel and it sparking, eventually got it started but it sounds really bad.
I've taken the cam belt cover off and can see that whilst the camshaft lines up the lower damper sprocket is not at TDC.
Have a look at the pics, I would say the crank is 15 degrees past the mark on the cover plate, what would cause a belt to slip.
The car was running fine up to starting today and has only covered 3000 miles since a new belt was fitted last summer, the belt is still tight.
I haven't taken the belt off yet but I guess loosen, remove and reset the crank TDC, then refit and see if any damage has been caused.
[/img]
