M Tech Steering Wheel
turkeysneck
I have an M Tech 1 steering wheel, am I able to change it for a M Tech 2 one with no issues ?
- **BANNED**
Yes.
Pop the centre badge out on the tech 1 wheel,using a 22mm socket,slacken the mounting nut,then using the ign key,unlock the steering lock,remove the mounting nut and the steering wheel.
Pull the centre pad from the tech 2 wheel and mount it on the column,lock the steering by removing the ign key,mount the 22mm nut and any washers removed and tighten properly.Replace the centre pad.
Youth is wasted on the young.
Jim320i
- E30 Zone News / COTM Team
Whats the Tech 1 like condition wise fella?
I'm after a good quality replacement/show one and then use my crap one as a daily wheel.
turkeysneck
It's mint but I can't bring myself to sell it.
Jim320i
Poo!
If you change your mind, give me a pm... In no rush for one anyway. The one thats in my car now is battered but will stay in there unless im going somewher nice, then when I get the replacemnt, it will be switched over for the day etc.
