320iAN
Post
Sat Aug 20, 2011 11:37 am
ive just got myself a set of mim 1900
3 wheels have cleaned up farily well but the fourth is coated in brake dust, ive been using COMMA Hyper Clean but on the heavy dust it's been no good.
thought i'd ask for some advice from others of what you'd recommend? i was going to go buy GUNK or TFR but don't want to wasting my time if they are not good enough?
the wheel
JJ26
Post
Sat Aug 20, 2011 11:46 am
I think your gonna need a proper acid wheel cleaner product to remove that. Get a long stiff bristle brush and a spray applicator and work it in. Keep it wet then rinse off with water.
Here is a good easy guide for you.
http://www.detailingworld.co.uk/forum/s ... p?t=178161
Never used this product myself however.
G/90 316i M40 tickety tic!
ST185 GT4
Archless! Tech 1 project
E46 330d Sport
320iAN
Post
Sat Aug 20, 2011 11:58 am
JJ26 wrote:I think your gonna need a proper acid wheel cleaner product to remove that. Get a long stiff bristle brush and a spray applicator and work it in. Keep it wet then rinse off with water.
Here is a good easy guide for you. http://www.detailingworld.co.uk/forum/s ... p?t=178161
thank's
wonder wheels is probably about the most acid based wheel cleaner i think i could buy locally?
320iAN
Post
Sat Aug 20, 2011 12:04 pm
just spoke to a mate & he recommended "oven cleaner"
spray it on, work it in and rinse it off.
320iAN
Post
Sat Aug 20, 2011 1:16 pm
320iAN wrote:just spoke to a mate & he recommended "oven cleaner"
couple of coat's of cif oven cleaner and it's deffo shifting the dust.. look's like the dust has preserved the original coating
Rtaylor2208
Post
Sat Aug 20, 2011 2:03 pm
Be carefull with the oven cleaner, fooked a set of wheels with that before, dont leave it on too long. I have used the swarfega wheel cleaner before on similar conditon wheels and they came up really well. Took quiet a few attempts and several brushes. I cant remember the exact name of the stuff but it comes in a 5 litre bottle for about £17.
I see your in west of scotland, so there is a place in Kilmarnock between the old food giant supermaket and the galleon swimming pool that sell it.
- E30 Zone Meets/Events Team
Post
Sat Aug 20, 2011 2:34 pm
Wonder wheels will shift any brakedust from wheels, and those MIM's will be ok after using it too.
320iAN
Post
Sat Aug 20, 2011 2:36 pm
thanks Rtaylor, i'm in West Dunbartonshire .. ive gave up trying to clean them
.. just going to take them to get bead blasted some time next week
that way i can polish the lip from the bare alloy & maybe spray the centres dark grey??
thanks again for all the help guy's
Kos
Post
Sat Aug 20, 2011 4:23 pm
iron x
wolfs chemicals
brown royal
meguires wheel brightener
and as already posted very cherry
personally i think that wheel is better of with a refurb.
320iAN
Post
Sat Aug 20, 2011 7:13 pm
looking more like i'll be getting them chemical dipped at some point this coming week
m8782538
Post
Mon Aug 22, 2011 8:50 am
wonder wheels should do the job, comes with an agitator brush too and is normally only around £10.00
Could take 2 or 3 attempts though. just remember to rinse the wheel very very well between applications and do not use it if the lacquer is cracked etc as it will remove the lacquer too.
320iAN
Post
Mon Aug 22, 2011 5:53 pm
m8782538 wrote:wonder wheels should do the job, comes with an agitator brush too and is normally only around £10.00
thanks but ive decided the best thing to do is have them chemical dipped & powder coated
black666
Post
Thu Sep 22, 2011 8:48 pm
the best way to remove brake dust and the like is patio cleaner brush it in with a scrubbing brush leave a little while and wipe it off
320iAN
Post
Thu Sep 22, 2011 10:34 pm
black666 wrote:the best way to remove brake dust and the like is patio cleaner brush it in with a scrubbing brush leave a little while and wipe it off
cheers mate.. ive since had them powder coated as it turned out to be ground in metal brake dust shaving's
