M52 Knock sensor
craigieeb
Post Thu Aug 18, 2011 8:59 pm
just been out in the tourer for a quick blat since putting the new engine in over the past few days,
1st nailed it, second nailed, smacked it in to 3rd, there was a little hesitation and then jabbed it in to 4th and it seemed to cut out for a second or 2?
what would cause this?
it happened with the old engine when i was at York raceway going up the strip,
and i put it down to the knock sensor, mebbies i was changing gear to harshly...?
Post Thu Aug 18, 2011 10:15 pm
Whats with the new engine squire?
craigieeb
Post Thu Aug 18, 2011 11:29 pm
The old one, I thought blew the headgasket,
(over heating, blowing like a volcano out the rad)
took it all apart, to find the gasket was mint, brand new almost,
then looked at the exhaust valve stems while the head was off
and they were....
white white, white white, white white, white white, BROWN BROWN, white white !!
so there is a crack in it somewhere,
and instead of going the S50 route, I just went out and bought a 328i
pulled the engine and plonked it in,
started first turn of the key this afternoon,
but this little problem has me a bit puzzled,
it only does it when im doing a harsh gear change,
and when it cut's out, if i take my foot off the accelerator, power comes back?
Driving normally, smooth gear change, it's mint
Post Fri Aug 19, 2011 12:57 pm
Craig, are you using standard inlet bellow? I can't remember.
Mick had a problem with his car at the pod, it was dying after each gear change. It turned out that the inlet bellow was being sucked inwards/ collapsing when he stabbed the throtttle wide open. He had a CDA air filter on it, which was obviously restricting flow a bit, so the inlet bellow was collapsing. On removing the CDA filter, it could breath better and didn't collapse inwards anymore.
Worth investigating and seeing what the inlet bellows do when revving the car in neutral. I think the problem was made worse on Mick's car when it was hot under the bonnet and the rubber elbow became softer.
Are you getting any warning lights on the dash when the fault appears?
craigieeb
Post Fri Aug 19, 2011 3:41 pm
I am just using the standard elbow from BMW
but it is connected to a BMC CDA
i'll take the car somewhere away from my whingy neighbours :-x open the bonnet, stamp on the accelerator pedal and see what happens on the inducion side of things,
When Mick told me his was doing that the last time out at the strip, i thought his filter must of been clogged up with sh1te and just needed a cleaning,
but yeah i'll defiantly look in to that :thumb:
oh and there is no warning light coming on when it happens
Post Fri Aug 19, 2011 4:34 pm
Do you have an "ebay tat alert" warning light? :)
craigieeb
Post Fri Aug 19, 2011 4:47 pm
it's carbon and it blends well with the bonnet :P
Post Fri Aug 19, 2011 5:04 pm
Confidence is high, I repeat, confidence is high. :D
craigieeb
Post Fri Aug 19, 2011 6:21 pm
BMC for sale anyone lol
just took it off, and went for a bit of a rash one :o:
nd yeah, thats the problem sorted,
now need I need to find a replacement
Post Fri Aug 19, 2011 6:23 pm
I've just got a chavvy Ripspeed cone filter and never had any problems mate.
Have you still got the ABS fitted on the touring? If not, then an early E36 325i air box will do the trick also
craigieeb
Post Fri Aug 19, 2011 6:49 pm
Aye the abs is still there for the time being, but it is coming off, the 4 pot brembos dont like it,
nor do I
but thats besides the point........
me fookin starter has just packed in :x
lol
Post Fri Aug 19, 2011 7:13 pm
E36 airbox FTW
I have changed the starter on my E34 auto twice in the last 12 months, and this one has also started to fck up... :cry:
craigieeb
Post Fri Aug 19, 2011 7:23 pm
1 Starter removed and a loner in it's way in about half an hour :D
sick as fook now like
hahaha
if i dont laugh i think im going to go mad :-x
I'll pull the abs off and stick in the E36 air box on, hopefully i can drive for a while without anything else going wrong...........
jimbob88
Post Sat Aug 20, 2011 9:39 pm
Is the m52 airbox not restrictive then? Most standard airboxes are fairly restrictive
power corrupts.....absolute power corrupts absolutely
My car
Post Sat Aug 20, 2011 10:13 pm
Nope, has been discussed before with plenty of other engines, BMW air boxes are designed to work, not just to fit :D
jimbob88
Post Sat Aug 20, 2011 10:32 pm
Sweet :)
My car
