Early Fuel Pump Wiring
mick_318is
Post Thu Aug 18, 2011 3:35 pm
Hoping someone has tried this before :D
On my 1984 323 it originally had an external fuel Pump that sits down on the N/S sill beside the petrol tank.
However due to the bracket holding the pump in place rusting away and is now NLA, I have decided to fit an in tank pump.
My query is this.
For the external pump on the N/S the +12V is a Green/ Violet 1.5mm feed.
Checking on the O/S there is the connector for the Sender/Brake pad wear/ Speedo.
In this connector on the car side there is also a 1.5mm Green / Violet feed, which on the "connecting loom" currently doesn't have a corresponding wire.
Is this the same feed? ( Pre wired for an in tank pump )
I have tested it and there is +12 V with the ignition.
What I do know is that the +12V feed for the pump is supplied from the fuel pump relay.
I want to ensure that this is indeed coming from the relay and not some other source.
I am not exactly sure where this relay is, can someone point me in the right direction.
If it is
From Realoem it appears that the loom changed over in 87?
I have another loom from a later car which has the Green / Violet however the connector is a different shape
My Car side of the connector is a white plug that is 3x3 where as the loom I have is black and I think 4x2.
Is there a post 87 loom that will plug straight in. Or will I have to cut /solder to get this to work.
E30less again.
Post Thu Aug 18, 2011 6:08 pm
Some early cars, including the only one I have with an external pump, have an in tank low pressure pump as well, so have the power feed split to both. Mine has the later plug and socket though, so I can't really answer you main question.
The green/purple at the plug should be the fuel pump though, along with a brown earth.
Post Thu Aug 18, 2011 6:13 pm
There are two different plugs for this, sept/oct 87 is the changeover. Bit of soldering does the job. 8)
