You'll need a switch that has enough poles to hook up to all the original up/down cables that go to the original switches, and a power feed.
It will also have to be heavy duty enough to handle the quite considerable current needed to operate all four windows.
Use a multimeter to measure the current needed to operate each window motor, add up those four figures and you'll have an idea of what current rating switch to use.
Elcetric Windows - Numpty Alert
Try these links:
http://bmwcarmagazine.com/forums/thread ... adID=61726
http://autoloc.carshopinc.com/product_i ... 238/WC1000
There's a far more elegant way to do it than this!Speedtouch wrote:You'll need a switch that has enough poles to hook up to all the original up/down cables that go to the original switches, and a power feed.
If you look at the wiring diagram for the windows, you will see that in the static switch positions, both wires to each motor are earthed, but each switch has two separate earth wires - one for 'up' and one for 'down'.
If you separate all eight earth wires into two groups of four, then fit a simple change over switch into them (must be break before make), with the common terminal going to the group of four, the normally closed terminal going to earth, and the normally open terminal going to 12 volts+, then things will work as you desire, without any problems of short circuits if more than one switch is operated at a time.
Problems that you will incur are that the existing power feed to the windows isn't strong enough, and that the overload cut out switch will likely trip. Don't be tempted to work without this switch - it's important.
You may get away with using two cut outs; one for a pair of windows. It can be fitted in line into one of the group of four earths, dividing them into two of two for the cut outs.
P.S: Total closure was an OE option on E30s.
