Light switch illumination & buzzer.
Wid77
Post Sat Nov 05, 2005 12:35 pm
Can anyone tell me if a light should come on to show you have selected parking and then headlamps? It is a pull switch on the right of the dashboard on my 1988 325i touring (not sure if this is the same in all other E30's?). There seems to be a small 'window' above the pull switch and i thought this may contain a bulb which has blown. I have had a look but i can't work it out. Also, was there no 'lights on' warning buzzer ever fitted? Cheers.
e30-320i
Post Sat Nov 05, 2005 12:55 pm
i think the light near the swich is for the fogs mate the only light that comes on with mine is the full beam under the speedo and as far as i know there is no buzzer there is a light that comes on with the handbrake if thats what you mean by parking
89 325i touring
Wid77
Post Sat Nov 05, 2005 1:45 pm
When i put the fog lights on (front or rear) i get a light showing this in the main binacle near the speedo and rev counter. I am trying to find out if there is any light to show you that you have your side or headlights on, other than on full-beam. From what you say, it doesn't seem that there is one, or a warning buzzer. Cheers.
Cloggy Saint
Post Sat Nov 05, 2005 1:50 pm
The window above the pull switch should illuminate when the lights are on. You can probably access it by reaching up through the under-knee panel.
stevo
Post Sat Nov 05, 2005 2:03 pm
datourer wrote:The window above the pull switch should illuminate when the lights are on. You can probably access it by reaching up through the under-knee panel.
mines illuminates all the time with the ignition on, well until the bulb blew that is :roll:
stevetigger
Post Sat Nov 05, 2005 2:06 pm
Same as but my bulb works winkeye , same as electric window buttons. On when ignition is on!
Cloggy Saint
Post Sat Nov 05, 2005 2:08 pm
you're probably right, i only remember that it definitely illuminates at some stage!
Wid77
Post Sat Nov 05, 2005 3:18 pm
I will have a look then to see if i can change the bulb as it must have blown. Cheers. :)
