coil wiring help 88 320 vert
lamby
i,m removing a clifford alarm due to A.not having fobs and B.it keeps cutting the car out.problem is not knowing where coil wires should go as they go into a clifford relay and there is only two wires?so i need to know where the wires originally went to so i can use the car.have taken out a lot of sensors etc but still getting fuel at fpr so this is the last bit(i hope)
Coil + terminal should be a green wire that comes directly from the ignition switch. It goes from the switch, through a plug and socket clipped half way down the steering column, across behind the dash to a two pin socket above the glovebox, fitted with a plug with a loop, (where the immobiliser should have been connected), up through the duct behind the glovebox into the fusebox. It passes straight through the fusebox with no connections, out to the 20 pin C101 engine loom plug beside the fusebox, then into the engine loom and to a coil. Inside the loom there is a single branch to the ECU.
The coil - wire is black, and goes to the ECU inside the engine loom. There is a single branch to the diagnostic socket.
lamby
oh nice, i have 2 white wires straight from coil into glove box relay thats it!have found the green loop so will go from there.car still turns over etc so i need to find where its been cut and redo.thanks would have left it alone but car unusable with alarm in,,then again it worse now
The original coil wires are "the end of the line" of the section of loom around the battery tray area, so search around there.
There's no predicting what alarm fitters have been up to, though!
lamby
thanks a lot,found them cut and wrapped above ecu!which was good news as i,ve reconnected them done away with so much wiring and blue cable splitter things,sorted all cut original wires and i now have central locking,which was on my list.now back to sorting out the fumes.
