hope it helps, any things unclear give me a shout.
cheers
Kev
bottom left is the fan with two speeds and an earth point
speed 1 connects through fuse 3 in the fusebox to relay k1 terminal 87
speed 2 connects through fuse 18 in the fusebox to relay k6 terminal 87
the temp switch has three pins '0', t1 and t2
'0' goes to fuse 19 (there is a small multiplug with about 6 wires going to it in the fusebox somewhere, check for continuity to the small green and black wire and cut it and join to terminal '0')
t1 goes to terminal 85 on relay k1
t2 goes to terminal 85 on relay k6
terminal 30 on both relays is already wired to 12v dc so you don't need to do anything
terminal 86 on k6 needs to go to earth
terminal 86 on k1 is already earthed so no need to do anything
