Lee Parkes' E30 Alpina B10.
staley_turbo
Post Mon Aug 15, 2011 7:09 pm
quite funny, good idea! :D
Bristol_Jer
Post Mon Aug 15, 2011 7:18 pm
Nice idea! :)
Post Mon Aug 15, 2011 7:24 pm
You taking a video too Lee :mad:
leeparkes
Post Mon Aug 15, 2011 7:28 pm
Rav335uk wrote:You taking a video too Lee :mad:
Lol, not a bad idea :mad:
leeparkes
Post Mon Aug 15, 2011 10:13 pm
winkeye
[youtube][/youtube]
You need the sound on.
Now, im no auto electrician but that dont look quite right, took a good few revolutions before it started sparking (apart from one at the begining) :? is this normal?
What about the pattern? ie, can any of you see any plugs 'missing'?
Post Mon Aug 15, 2011 10:16 pm
Have you changed the coil over for a good one??
leeparkes
Post Mon Aug 15, 2011 10:46 pm
I did test the coil with a multimeter and it came out ok.
Post Mon Aug 15, 2011 10:47 pm
You're right, it doesn't look as strong as it should be, and I couldn't make out if all six are firing. Also, what's the firing order on these?
leeparkes
Post Mon Aug 15, 2011 10:57 pm
No idea what the firing order is Maurice, i used an old dizzy cap to work out which terminal was which in a clockwise order.
Post Mon Aug 15, 2011 11:02 pm
Change the coil :D
leeparkes
Post Tue Aug 16, 2011 12:10 am
leeparkes wrote:No idea what the firing order is Maurice, i used an old dizzy cap to work out which terminal was which in a clockwise order.
Like this :)
Ive no idea on the coil, i tested it with a multimeter and it was fine, can anything else go wrong with the coil?
johnl320
Post Tue Aug 16, 2011 12:32 am
Thats a hell of delay from initial turning over to actual sparks, apart from like you say the initial one. If it was mine I would be checking every electrical connection associated with the igntion system especial around the crank sensor and its wiring, the coil and its wiring and all ecu, dme and earth connections.
leeparkes
Post Tue Aug 16, 2011 4:29 pm
After watching the video over and over again all 6 do fire but it actually take about 5 revolutions before it starts sparking :?
Now i only know basic electrics ie i can measure voltage and resistance at terminals etc.
Crank pos sensors resistance is within spec when cold but raised when warm (apparently its normal) shook and twisted the wire with the multimeter on but no change in resistance.
http://www.e30zone.net/modules.php?name ... ight=crank
Ive tested CPS resistance at the ECU plug and was the same, there's another terminal on the CPS plug, whats that for?
Im getting 12 volts at the coil terminals and the coil was tested for resistance, all fine.
Is there a Brian Moooore on M30 engines out there :D I bloody need one :cry:
leeparkes
Post Wed Aug 17, 2011 9:25 pm
Well ive been at it again today, removed the rad to give me some more room (which took about an hour to get off :mad: ) must sort the bolts out before it goes back in.
Anyway nothing has come to light and everything seems normal :?
Got to put it all back together now, this is how i left it.
:cry:
Post Wed Aug 17, 2011 9:45 pm
Try the same test again with the plugs on the plate but with a different ECU, the ECU tells the coil when to fire on these so the delay IMO is something to do with the ECU/coil/crank sensor
walinsky
Post Wed Aug 17, 2011 10:54 pm
... or the DME relay
leeparkes
Post Thu Aug 18, 2011 10:48 pm
... or the loom.
Havent touched the car today but Dan youve got me thinking, if the ECU is a dud will the Eprom chip be ok, ie can these get damaged? Maurice do you know anything on this?
Apparently these were re-mapped by Alpina.
Post Thu Aug 18, 2011 11:38 pm
The chip should be OK. Potentially, they can be damaged, or suffer degradation over time, but it's a rare event; see this article:
http://my.ais.net/~xtreme/SF/Bit-Rot/
It will indeed probably have been reprogrammed by Alpina. I can supply an upgrade chip for the M30B35 if required, in the unlikely event that yours is faulty.
I doubt if the ECU is dud, but it's certainly worth trying a spare if you can.
The chip can be used in any later six-pot ECU, e.g., 172/173/179/380/381, etc., although the 179 is the correct one for a later M30B35.
Post Fri Aug 19, 2011 12:07 am
thats some delay on the spark and definatly worth following up, but an ingenious idea for testing !
these old ECU's can suffer badly from dry joints, i have a few good know one's should you need one to try?
whats the condition of the cps ? is it in the bracket nice and tight ?
leeparkes
Post Fri Aug 19, 2011 6:05 pm
Thanks for the kind offer Steve i may take you up on it :D
CPS is in spec and religiously gapped to the toothed wheel @ 0.90mm.
leeparkes
Post Tue Aug 23, 2011 11:28 am
Right, the car is all back together but the problem is still there :(
Cleaned every plug on the loom with contact cleaner with no joy.
e30topless wrote:these old ECU's can suffer badly from dry joints, i have a few good know one's should you need one to try?
Pm on its way. :)
leeparkes
Post Fri Aug 26, 2011 11:32 pm
Come on Steve :cry:
Post Fri Aug 26, 2011 11:37 pm
Lee, if he don't come good, I have one you could try mate.
Post Fri Aug 26, 2011 11:41 pm
PM replied Lee, sorry for any delay :o
leeparkes
Post Mon Aug 29, 2011 5:10 pm
Right ive tried 3 ECU's on this now, the original Alpina one, my original M30 one and this morning tried a 380 from an M20 with my eprom (tried both standard and Alpina chip) but it hasnt made a blind bit of difference. :(
Now i noticed something this morning, at the scrapyard i relieved a touring of its headlight wash wipe kit and tested it on my own car. When testing the washers i noticed that near my washer jets fluid was pissing out of one of the pipes. When the bonnet is shut its pissing all over the loom at the bulkhead. When i say pissing i mean its as much what hits the windscreen. :?
One other thing ive noticed is when i unplug the ICV it seems to smooth the idle out and there's no hesitation when reving, :mad: idle sits at around 900rpm (which supposed to be normal with this donk) tested ICV and re-cleaned it out with carb cleaner but still the same.
I fookin hate electrics :banghead:
Im going to try an source another loom now because really there's nothing else to test. How rare are M30 manual looms nowadays?
leeparkes
Post Mon Aug 29, 2011 5:27 pm
I remember folk back in the day using M20 looms with minor mods (anyone remember what the mods are?) im sure i have an M20 loom up the shed somewhere.
Can an auto loom be used easily?
E30SPORTMAD
Post Mon Aug 29, 2011 8:32 pm
leeparkes wrote:I remember folk back in the day using M20 looms with minor mods (anyone remember what the mods are?) im sure i have an M20 loom up the shed somewhere.
I have 2 M20 325 looms here Lee and a M30 auto loom and can get a couple M30 man looms if need be? only thing is there not that cheap anymore :(
leeparkes
Post Mon Aug 29, 2011 8:41 pm
I saw you have an M30 auto loom for sale :) is it from an E34/32?
From what i remember the TPS plug is different on the auto but not sure if a manual TPS can be bodged onto it.
Ill get back to you buddy asap.
E30SPORTMAD
Post Mon Aug 29, 2011 8:46 pm
leeparkes wrote:I saw you have an M30 auto loom for sale :) is it from an E34/32?
The M30 auto is from a E32 with electronic Throttle body so may be hard to splice it up, i reckon u cud build 1 if u had a M30 man loom beside it as there is alot of spare wires in the auto loom? will try get u a good price for a man loom in the mean time,
leeparkes
Post Mon Aug 29, 2011 9:14 pm
Ahh, i remember now, i think ill pass on it then :D
Yes keep your ears open for manual loom, thanks!
E30SPORTMAD
Post Mon Aug 29, 2011 9:20 pm
No problem your better off getting the correct part to plug and play again, will keep you posted when this other man gets back to me, :D
leeparkes
Post Mon Aug 29, 2011 9:23 pm
Is it the guy in NI, on 5forum call skoda?
E30SPORTMAD
Post Mon Aug 29, 2011 9:27 pm
leeparkes wrote:Is it the guy in NI, on 5forum call skoda?
No not him, thats who i was telling you about a wile back he has an E34 M30 manual but not breaking it just yet, this other man is from Lincolnshire,
leeparkes
Post Mon Aug 29, 2011 9:29 pm
Work your magic on him then mate :)
E30SPORTMAD
Post Mon Aug 29, 2011 9:31 pm
Will try my best have sent him a message but no reply yet,am off to bed now catching early morning ferry to Stranraer so need some sleep have a long days driving ahead of then, :D
