Fuel tank refitting....
Kedge
Post Mon Aug 15, 2011 10:39 am
Currently trying to fit 63 litre tank into my 316. Any tips on getting it to go in as it just doesn't seem to want to go in no matter what angle I try :s
I'm starting to consider taking of the external pump mounts as they seem to be giving me grief but I'm sure there must be some simpler trick I've not sussed yet!
Instagram - Kedge85
Duke137
Post Mon Aug 15, 2011 10:53 am
Dave how have you got round the secondary sender not having an access point?
Is it a connect it all first job? :?
Watching this thread as I am doing the same thing to my 316
Kedge
Post Mon Aug 15, 2011 11:00 am
Hi Ferg, here's what Brian had to say about the sender unit;
Brianmoooore wrote:In series with the one in the pump assembly. Disconnect the brown earth wire from the pump sender, connect another wire in its place, and connect this wire, plus the extended brown wire to the sender on the LH side.
Note that the two sender set up uses a different gauge in the cluster from the single sender set up.
(Written from my laptop by the banks of the Loire in France, and on the wrong side of a bottle of Cotes du Rhone, so I hope the above makes sense!)
The more attempts I have getting this tank in the more convinced I'm getting about the beam having to come out, I know this shouldn't be the case but I can't see how the tank fits with it in place despite the fact the original tank came out easily! :-x
Instagram - Kedge85
Duke137
Post Mon Aug 15, 2011 11:08 am
Kedge wrote:Hi Ferg, here's what Brian had to say about the sender unit;
Well I remember the last time I took a tank out it just dropped free?
The rear beam is coming out of mine in the next few days so I think I will do mine at that stage....
Let us know how you get on please mate, good luck
Kedge
Post Mon Aug 15, 2011 12:31 pm
Yea, all the tanks I've done before drop nice and easy, this isn't even close to going in! Thrown the towl in for the day as all I've done is scratch a load of paint off the tank!
If your taking your beam out definitely do it then!
Instagram - Kedge85
