new to BMW ownership
groovylee
Post Sun Aug 14, 2011 5:44 pm
hi all, i might be getting my hands on a 1989 320 auto convertible in the next few days, but she has been stood for about 2 years, so i was wondering if there is anything you would recommend to attend to first? the car was a runner before it was laid up, and i know it's background for at least the last 15 years, and it was well looked after.
sorry it's a bit vague, i don't have all of the details yet. it is basically a friends parents car, and they don't use it any more, so i might be getting it very very cheap :)
thanks everyone,
Lee
Jim320i
E30 Zone News / COTM Team
Post Sun Aug 14, 2011 6:00 pm
Give it a proper good service mate, but check it over for rot etc first. Might not be worth spending money on in the long run if the bottom has rotted away... Any pictures yet?
groovylee
Post Sun Aug 14, 2011 6:38 pm
hi jim, no pics yet as only just (maybe) struck the deal today so i was after a few pointers on what to look out for. i'm thinking full service, new tyres(?), damn good clean to look for any paint defects/rust etc. i believe the floor pan and arches/sills etc are solid, so shouldn't be any nasty surprises there.
i'm tempted to drop it in for an MOT and see what comes up??
will get pics as soon as the deal is struck, and then maybe start a project thread?
cheers,
Lee
Post Sun Aug 14, 2011 7:08 pm
Cam belt would be high up my list of priorities, or at least check when it was last changed.
Jim320i
Post Sun Aug 14, 2011 7:34 pm
Yeah, like Brian said, look into the cambelt as thats the last thing you want snapping once you fire it up... For the price of a cambelt kit and if you are able to change it yourself, seem pointless not doing it to be honest.
Rust spots, check the scuttle panel areas, arches, under the carpets, in the boot under the carpets too etc. Just look for the obvious though.
Taking it for an MOT just to see if it passes is always a good idea if you can get the bit sorted in the time it takes for a free retest etc.
But just to echo what Brian said again, look into the cambelt as if its been sat for 2 years, it might have gone very frail!
Where are you located? A local zoner might be able to assist you. If your in Leicester, I always got time to come and help out. :cool:
A Build thread would be cool aswell as its always nice to see the progress and its always good for you to look back at yourself.
groovylee
Post Sun Aug 14, 2011 8:26 pm
brian, jim, many thanks for reminding me of the one thing i had forgotten about in the excitement, the cambelt :o: i am a mini and alfa romeo guy normally, so am unsure of the BMW side of life. are the cambelt changes relatively simple on these? and what is the recommended interval? i believe it is an M20 engine. thanks for the offer of help Jim, unfortunately i am a bit far from you. the car is in Hitchin, herts at the moment, and will be getting to shefford beds as soon as i can do it. the car is a freebie as it is clogging up the drive, so i will definately be doing a build thread :D :D
oh, and one last question. is there a parts place that all BMW drivers use, or is it a case of the usual suspects?
many thanks,
Lee
Jim320i
Post Sun Aug 14, 2011 8:39 pm
Cambelts on the M20 is every 4 years or every 40,000 miles iirc :?:
They aren't too difficult to do at all to be honest, if you competant enouigh with a spanner to do usual works then tackling the cambelt wont be too hard. Loads of threads on here with guides, or a good old Haynes manual will also help you out.
As for parts etc, give meatballs82 a message on here. Tell him Jim said he is a cooont :twisted:
He works at Euro Car parts and gives us good discount, he gives even better discount if you tell him his voice sounds sexy winkeye
Other parts you are in need can always be sourced on here or Ebay but with regards to servicing parts, obviously always buy new and good quality parts :thumb:
If you get stuck with owt, pop a thread up in the tech section and someone will be able to give the answer quick enough....
And get some pictures soon! :cool:
groovylee
Post Sun Aug 14, 2011 9:23 pm
awesome, cheers Jim :D
Post Sun Aug 14, 2011 9:27 pm
For parts, as well as the above, there's always BMW themselves.
BMW support for their older models is second to none - most parts are available, and even some that are NLA become available again from time to time if demand is great enough.
Some genuine parts are extremely cheap, others are outrageously expensive, but in general much cheaper than comparable parts from other makes. Always worth enquiring from our tame BMW dealer in the genuine parts forum.
Save this in your favourites folder: http://bmwfans.info/parts/catalog It's essentially the same as what your BMW dealer uses at the parts counter.
groovylee
Post Sun Aug 14, 2011 10:05 pm
cool, cheers Brian :D
**BANNED**
Post Mon Aug 15, 2011 12:35 am
Cambelt swap before running the engine,if you can manage it!
Do the waterpump whilst you have it in bits,you have to pull the radiator out,so back-flush that as well.New plugs,get an MoT and see what that throws up first.
After that,I would treat every rubber bush as suspect....
New discs/pads/dampers will all help make it drive better.
Cambelt really should be 30k/three years,Jim!
Youth is wasted on the young.
groovylee
Post Mon Aug 15, 2011 5:55 pm
thanks for the advice daimlerman, i will see if i can get the belt done before i move it. i guess it depends how quickly they want it off the drive :wink: i have also heard that it is worth sending the injectors off to be cleaned? any recommendations or ideas on price?
photos tonight :D
cheers,
lee
Jim320i
Post Mon Aug 15, 2011 6:03 pm
Injectortune on here does them for £10 each iirc? Someone should be able to confirm that though.
Usual price is anything from £12-£20 each to my knowledge so worth doing... Something I still need to do with a spare set I got.
If you are wanting to drive the car straight the way, you can usually pick up a set of injectors from around £10-£20 and have them send off, but if your not driving it, then its not worth buying a spare set.
@Malc - You sure its 30k? Seems a bit soon...
**BANNED**
Post Mon Aug 15, 2011 6:56 pm
Here's a link to the Injectortune thread;
http://www.e30zone.net/modules.php?name ... c&t=152878
I have used this service twice,now,and can reccommend without reservation.
Yes Jim,I swap belts at 3years/30k miles,for the sake of a £10 belt,why take a chance?...belt lets go,engine re-build is what,£2k?...
Jim320i
Post Mon Aug 15, 2011 7:24 pm
Ohh yeah, fully understand the sake of £10 and a new belt, I just thought it was 40k change over... I'll be changing mine at 30k now you've said this though... Only just done mine though so all quiet on the western front for a few years atleast :cool:
groovylee
Post Mon Aug 15, 2011 9:54 pm
well, some very poor pics are now in the general chat forum :D
munichman
Post Tue Aug 16, 2011 1:20 pm
I see you are in Hitchin. The folks at A1 BMW in Stevenage have loads of s/h parts and are very experienced and good for help, or doing any work you can't.
Also Bury Road BMW are reputable and work with Old Colonel Cars (classic BMW dealers).
Enjoy the car!
munichman
Post Tue Aug 16, 2011 1:24 pm
Bury Road BMW are in Hatfield! (07930 842105, I think)
A1 BMW - http://www.a1bmspecialist.co.uk/
(PS: I have no commercial/business connection with either!)
