Hiya This is my first post due to being a new E30 owner! so any help and advise would be great!
Ive got stright in the deep by converting a 316 in to a M60b30 which ive done now for a drift car my problem is after installing a hydralic handbrake then ive gone to bleed the brakes as normal i get fluid to the back calipers fine but then hydro goes solid and back brakes lock on, i can only release the back brakes by releasing the fluid out.
but then i go to bleed the front brakes and theres no fluid what so ever, ive tryed manual pump and easy bleed throught the airline, I took the brake pipes out of the master cylinder and theres nothing coming out of the M/C
Im just wondering if anyone has had this problem in the past.
Many thanks
E30 Brakes Questions
e301988325i
Sounds like your hydraulic handbrake is set wrong and not allowing the pressure to drop after the brakes have been applied.
I said:
e30topless said:
lock the wife in there
