TDC Valve positions
bluff467
Post Sun Aug 14, 2011 7:37 am
I am going to put my cylinder head back on to the engine today, m20b25, but I just want to make sure that the valve positions are right before I do so. No 1 and 6 pistons are up, so should the valves for no 1 and 6 be closed when I put the cylinder head back on?
Life is short so enjoy it while it lasts. Buy an E30!
E30_Crazy
Post Sun Aug 14, 2011 9:45 am
Just turn the crank about 25-30* clockwise and all pistons should be at some level of mid-bore. Then get the head on, and tightened down. Turn the cam gear until the notch and line are inline (TDC for cam) and then turn the crank back the 25-30* to TDC, and it will be all lined up for the cam belt.
Post Sun Aug 14, 2011 11:16 am
bluff467 wrote:should the valves for no 1 and 6 be closed when I put the cylinder head back on?
One set or the other should be partly open.
As said above, never put a head on with any piston completely up.
bluff467
Post Mon Aug 15, 2011 6:14 pm
When I line the marks up on the cam does it matter which valves are open and which are close, or are the valves automatically in the right sequence when the marks are lines up?
HairyScreech
Post Mon Aug 15, 2011 6:16 pm
the timing marks should be tdc number one cylinder, thus if you put both the cam and crank to there timing marks you cant really get it wrong.
