E30 S50B32 S366 Turbo - 606hp/607nm+ @ 0.95bar boost
Dave_M3
Post Fri Feb 04, 2011 2:19 pm
Jhonno wrote:Jesus.. Bet that goes well! :twisted:
Nice curves also..
+2!!!
And you say there's even a flatter and higher curve to come!!!
Going to be mental :mad:
But definitely in a good way :D
Gunni
Post Fri Feb 04, 2011 3:27 pm
as you can see from the dyno the power isn´t coming on until after 4k and it´s actually wanting to make power towards 8k, but this engine won´t be reving that high so I´ll be altering the cam timing to move the low end down and then bump up boost a little bit.
It´s going to make way more torque and for sure more power.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
craigieeb
Post Fri Feb 04, 2011 3:46 pm
Awesome
just
Awesome
Dave_M3
Post Sat Feb 05, 2011 9:11 pm
Ah, didn't really see the rpm range that well the first time... iphone screen is pretty small :p
Still not at all too shabby and looking forward to the developments :)
eta
Post Sun Feb 06, 2011 3:38 pm
That is quite impressive Gunni.
Gunni
Post Sat Jul 09, 2011 1:59 am
Santa-Pod
Gunni
Kos
Post Sat Jul 09, 2011 2:02 am
looking forward to it :D
www.pukardesigns.com
IG Pukar.Designs
oddisE30
Post Wed Aug 10, 2011 9:09 pm
Nice work man! Nice to see there's a good breathe of E30 turboes up in Iceland to match your volcanos. There will never be to many S50 turboes winkeye
Interesting dyno results, you drive on 98 octane pump fuel right?
I'm working on my B30 turbo setup (95 octane) and have talked alot to the Andreas@ PPF and they have started to offset grind the cams to less duration with good results, rapidly decreasing the engines knock sensitivity. Remenbering they had to adjust down the boost and pegging down a 595whp B32 turbo to 523whp to be safe within the limit of knock with stock cams.
They even recon to get 600hp in the engine on a B30 I'll need to offset grind the cams and drop til C/R to about 8,0-8,5:1. Your dynoboost is then very interesting in that respect. Not lots of non E85 turboed S50 around to compare to.
Have you endured problems with the crank case ventilation? Lots of S50 turboes seems to have those problems. I see they weld on a ventilation pipe from the valvecover to try to ease. Don't know what I'll do about that yet..
Keep up the good work.
Gunni
Post Wed Aug 10, 2011 9:45 pm
This car is in the UK.
It uses 99octan Vpower fuel only
It shows no tendancy to knock at 1bar boost so far.
Crank case ventilation has not been a problem.
Gunni
Dave_M3
Post Fri Aug 12, 2011 10:15 pm
Gunni wrote:This car is in the UK.
Shows how well put together and well thought out it is innit? :cool:
