hey guys, my car is actually an e21 NOT an e30. but the principle is the same - well nearly lol. i have tried searching but i cant find a definitive answer!
I have already done the m50b25 swap into my e21 but as most of you found the boat anchor is not good enough so I have a e36 328i donor car.
When I did the swap i used an 2.3 m20 clutch and cover (as it was new on my last car and being a tight bugger i reused it!) found out that it slips a bit when you change gear too quick.
My question is can the e30 325i stock m20 clutch handle the m52b28 with a BB Throttle body and the m50 inlet? if not which clutch do you guys use?
if anyone is wondering - I HAVE to use the e21 m20 gearbox cos my speedo is cable driven and not electronic like you boys have.
m52b28 on an m20 box - clutch question
Nas80
im clearly having a blind moment - there is a sticky thread in this section about gearbox options - and it says use the 325i clutch and cover if you use the m20 box.
I should clarify that I am using the m20 single mass flywheel already and the boxes are the same apart from mine has a speedo cable output..
seriously though i would appreciate it if someone posted - yeh Nas the 325i stock clutch can easily handle the power no probs.
in an e21 its a whole engine out job if i need to change the clutch!
redcar
I've seen a lot of the sachs ones if that helps
M20 clutch is good for over 300hp
redcar
just out of interest, how much power can an m40b16 gearbox handle?
duracel79
Over 300, but how much over for a race application? I need closer to 400bhpDanThe wrote:M20 clutch is good for over 300hp
Nas80
Cheers for being helpful guys.
I dont race track and i wont be going over 300hp as my axle would simply snap in half. I was about to buy an expensive uprated one so you have saved me a fair chunk of money.
i have had a paddle clutch in my previous rx7 and often made myself look a complete n00b trying to set off in traffic.
the sound of 400hp in an e21 = insane speed and plenty of danger. I like!
