Fuel Sender Wiring.....
Kedge
Post Fri Aug 12, 2011 12:27 pm
I'm just in the process of soldering in the fuel pump loom into my 316 for the intank fuel pump.
Question i have is that for the second sender unit on the passenger side, where do i wire this into?
Dave
Instagram - Kedge85
Kedge
Post Sat Aug 13, 2011 11:25 am
Anyone?
Instagram - Kedge85
Post Sat Aug 13, 2011 7:52 pm
In series with the one in the pump assembly. Disconnect the brown earth wire from the pump sender, connect another wire in its place, and connect this wire, plus the extended brown wire to the sender on the LH side.
Note that the two sender set up uses a different gauge in the cluster from the single sender set up.
(Written from my laptop by the banks of the Loire in France, and on the wrong side of a bottle of Cotes du Rhone, so I hope the above makes sense!)
**BANNED**
Post Sat Aug 13, 2011 8:03 pm
Brianmoooore wrote: (Written from my laptop by the banks of the Loire in France, and on the wrong side of a bottle of Cotes du Rhone, so I hope the above makes sense!)
Check 'Chat',I was getting worried!
(Gigonda's is the 'better' Cotes du Rhone,BTW)
Youth is wasted on the young.
Kedge
Post Sun Aug 14, 2011 6:32 pm
Thanks Brian, that sounds simple enough :notworthy:
I've already switched to a 325i cluster so that's no issue issue with the gauge.
Enjoy your holiday :D
Instagram - Kedge85
