Battery drain, Fuse 27 , just stuck, need some help =]
dude2k85
Post Wed Aug 10, 2011 10:37 pm
Hi there!
i have a 200mA drain through fuse 27 on my 325i.
i have read a few posts and looked in the bentley, and i can´t seem to find the problem.
the fuse is for central locking,interior lights,radio amp,alarm system and doorlock heating.
the central locking works, and i have no bulps in the interior lights, i don´t have a radio amp, and i don´t have the heating system.
i have the factory oem alarm system(extra cylinder drivers door), it dosn´t work i think. can i unplug it? and how?
this is a way to much drain on my battery.
have you guy´s any ideas?
thanx
FrikkiR
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Aug 11, 2011 1:08 am
I'd disconnect each door in turn; for the front doors there's a plug on the door jamb (between the hinges). Measure drain, disconnect a door, measure drain again until you've either ruled out the doors, or identified which one is causing problems.
If it is a door, it's then a slow process of taking the door card off and unplugging each element inside (central locking actuator, microswitch or lock heating element).
Also, just because your lamps have no bulbs in doesn't mean they can't be shorting out across their terminals.
dude2k85
Post Thu Aug 11, 2011 11:33 pm
i have a hard time getting the plugs out but ill try harder with some tools, and be ready to do some soldering. :mad:
i have taken out the relay for the interior lights that is behind the front speaker drivers side,
so i don´t think it´s the lights. :)
but about the plugs in the Apillar, is there a trick to get them or? are they just so freaking stuck!
thanx mates!
FrikkiR
mrLEE30
Post Sat Aug 13, 2011 10:09 am
Not sure if on same fuse but it's normally the boot light causing this type of drain, the switch fails and light always on.
**BANNED**
Post Sat Aug 13, 2011 10:58 am
dude2k85 wrote:i have a hard time getting the plugs out but ill try harder with some tools, and be ready to do some soldering. :mad:
thanx mates!
FrikkiR
Pull the rubber cover off,then squeese the two tabs,but they can be playful sometimes!
Going back,fit the rubber cover,then push the plug home.
Have you done the 'red/black wire mod'?
If not,have a rumage through the zone wiki,tab at the head of the page,it's under 'central locking issues'.
Youth is wasted on the young.
dude2k85
Post Thu Aug 18, 2011 7:02 pm
do i understand it right? , is there 12V from the A-pillar plug and to the door and there back again? , live voltage with no use? am i correct? for the door lock heater, part of the door loom?
and another question :
i replaced the voltage regulator in my alternator because it was charging sometimes on 12.4v and then sometimes on 13.2v, bought not a OEM part from bosch but a aftermarket from "some company" , and now it charges on 14.4 when there is no load, and with all the lights on and the air blower 13.9-14.0. is this normal? ,
thanx guys
FrikkiR
Post Thu Aug 18, 2011 7:13 pm
dude2k85 wrote:do i understand it right? , is there 12V from the A-pillar plug and to the door and there back again? , live voltage with no use? am i correct? for the door lock heater, part of the door loom?
thanx guys
FrikkiR
Yes to the 1st question, there is a constant 12v loop in the door, and by doing the Red/Black mod, it does away with this.
Seconde answer is Yes, that reading for the alternator on charge is correct.
dude2k85
Post Thu Aug 18, 2011 7:17 pm
thank you very much for a quick answer.
but this red/black mod , is it just in the drivers door? , there is only a 12v loop through the drivers door?
FrikkiR
Post Thu Aug 18, 2011 7:18 pm
Yep, drivers door only.
