Miris325i
Post
Tue Aug 09, 2011 2:41 pm
Hi, i started to change my front 45mm to 51mm with B6 dampers. Everything went smooth till i tried to get wishbone out of the leg. Any advice please?
Thanks Miris
1988 327i M-tech II...stolen
1993 316i touring...V8 build
12345kevin
Post
Tue Aug 09, 2011 2:51 pm
You'll need a "fork" type ball joint splitter. Put plenty of grease over the rubber boot and it shouldn't split if you take care.
Post
Tue Aug 09, 2011 3:27 pm
Undo the nut so far that the top of the thread is protected and give it a whack with a hammer.
Never fails.
Miris325i
Post
Tue Aug 09, 2011 3:52 pm
12345kevin wrote:You'll need a "fork" type ball joint splitter. Put plenty of grease over the rubber boot and it shouldn't split if you take care.
do u mean something like that?
http://www.ebay.co.uk/itm/ROLSON-8-200m ... 2a129cafd0
so use that with loads of WD40 and thats it? "fork" put between ball joint and leg and just wobble till will split?
Post
Tue Aug 09, 2011 4:18 pm
You often find a machined flat next to the ball joint that you hit with a hammer to jar the joint loose. A blowlamp may help, and PlusGas is a better penetrating fluid than WD40.
12345kevin
Post
Tue Aug 09, 2011 4:24 pm
Miris325i wrote:12345kevin wrote:You'll need a "fork" type ball joint splitter. Put plenty of grease over the rubber boot and it shouldn't split if you take care.
Yep, one of those, I would use grease to ensure it slides. And you need to hit it hard with a hammer.
Miris325i
Post
Tue Aug 09, 2011 9:51 pm
Thanks it worked
