Help removing autobox loom
Baurluvva
Post Tue Aug 09, 2011 1:35 pm
Hi all,
Please can someone help me? I am trying to remove an autobox loom from a 94 316 touring. Someone bought it and requires all the bits to make it run! It has a std box not switchable.
please help its doing my head in!!
Post Tue Aug 09, 2011 1:43 pm
You want the loom in one piece? I really couldnt be bothered unless the car is pretty much bare
Baurluvva
Post Tue Aug 09, 2011 1:51 pm
Not necessarily 1 peice but need to be able to reconnect where I cut! The guy needs it for a project trike!
12345kevin
Post Tue Aug 09, 2011 2:39 pm
Surely if its a "non-switchable" there will not be any loom or connections for the box other than the reversing light and inhibotor switch ?
Baurluvva
Post Tue Aug 09, 2011 5:28 pm
These are the wires i'm left with.....
Baurluvva
Post Wed Aug 10, 2011 10:52 am
What bits do I remove and how? I need to get this done friday!
Baurluvva
Post Thu Aug 11, 2011 9:12 pm
:eek: bttt
12345kevin
Post Thu Aug 11, 2011 11:06 pm
I wouldn't of thought you would need any of those connectors to "make it work". They would however make it easier to wire a reverse light and the inhibitor circuit to stop you starting in gear.
Post Thu Aug 11, 2011 11:11 pm
it's quite easy, remove the carpet and trace the loom across the passenger side footwell, it all leads to the underside of the glovebox which is best removed,
if the car you are taking it from needs to run again re-connect the Black/yellow wire to the spare Black/yellow plug you will find coming from the accessory socket area which in turn connects to the ignition switch
the autobox "loom" is basically the inhibitor circuit which won't really matter if it's going in another car, all it does is stop the E30 starting up in any gear
Baurluvva
Post Thu Aug 11, 2011 11:16 pm
Ahh thank you!
**BANNED**
Post Fri Aug 12, 2011 11:50 am
Start under the glovebox;
see that black/yellow under the main harness?
and those two plain blacks close to the glovebox hanger?
I had just removed the blacks from the black/yellow(that's the starter signal wire!)
Trace those two blacks down to a relay mounted under the accessories socket/dash loom plug and remove,trace the rest of that sub harness back to the plug that connected to the auto shifter thingy.
You will need the carpet out to remove this sub harness intact.
Youth is wasted on the young.
Baurluvva
Post Tue Aug 16, 2011 7:17 pm
The gearbox itself only had a screw in connector with 2 wires coming from it. What were they for?
If I wanted to run the engine and box without the inhibitor loom what would I need to connect?
I dont really want to start pulling carpet up if the engine will run fine without having the loom!!
**BANNED**
Post Wed Aug 17, 2011 9:18 am
Baurluvva wrote:The gearbox itself only had a screw in connector with 2 wires coming from it. What were they for?
First part;
Not seen an autobox close up,but I would guess that's the reverse light switch.
Second bit;
Refer to my photo above,the inhibit circuit breaks the starter signal wire,the black/yellow.All you need to do to start the car is to remove the two blacks from the black/yellow's and join the black/yellow's together.
But remember,the car will now start with the selector in any position....
Baurluvva
Post Wed Aug 17, 2011 9:24 am
Thanks. The info I also need is for the new owner, if the two wire connector on the gearbox is for reverse and inhibitor - how can he get his engine and box workng?
Post Wed Aug 17, 2011 9:30 am
There is no loom associated with an ordinary auto. gearbox. No electrical connections to it at all, and if I bought or sold an auto. box, I wouldn't expect to send or receive anything electrical.
Reverse light switch, inhibitor switch and the bulb that illuminates the selector scale are all part of the selector lever assembly, inside the car.
The switchable auto box has a multipin electrical connector on it, but still uses the same electrics associated with the selector.
**BANNED**
Post Wed Aug 17, 2011 9:38 am
Baurluvva wrote:Thanks. The info I also need is for the new owner, if the two wire connector on the gearbox is for reverse and inhibitor - how can he get his engine and box workng?
No,I think the gearbox wires are for the reverse light,the inhibit switch connects to the selector,it's harness starts under the glovebox at the black/yellow,goes via two blacks to a relay by the accessories socket,then three wires(a brown plus two more)go under the carpet to the selector.
Now when I built my cabbie up,I had problems getting it running,then remembered that it had been an auto in a previous life(but came to me as a manual)so when I pulled the M40/manual'box out,I unplugged the reverse light switch from under the car(at the 'box)...then with the replacement in I found the butchered selector connector...and traced it back from there!
Is the autobox replacing an autobox with the new owner?
Baurluvva
Post Wed Aug 17, 2011 4:08 pm
The engine and autobox are out of my 94 1.6 touring and going into a trike! The guy wants enough to get it running.
**BANNED**
Post Wed Aug 17, 2011 4:54 pm
Bloody heck!
Where do you start?
You'll obviously sell the guy the engine/autobox as a unit,the engine loom/ECU...but where do you go from there?
The guy will need the body side of C101(engine loom/body loom connector)enough harness to connect to whatever system he intends to use...
May be better to invite him round and suggest that he helps himself to what HE thinks he needs,and agree a price!
Post Wed Aug 17, 2011 5:25 pm
All he will need in the electrical dept. are the engine loom and everything associated with the engine that the engine loom connects to, such as the ECU and AFM .
No real point in him fitting up the C101 plug and socket, as very few pins of it will be used, and it will just take up space.
He will need to connect the thick red from the engine
loom to his battery + and the thick brown/orange wire to his battery -.
Chop off the C101 plug, connect the green wire to the 'on' position of his ignition switch, the black/yellow to the 'start' position of his ignition switch, and the purple/green, via a 7.5A fuse, to his fuel pump.
Connect a thick earth lead between the engine block and battery -, and another nice thick wire between the battery + and the outer 13mm terminal (nut size) of the starter motor solenoid and it's all good to go.
If he wants a rev. counter, than that connects to the black wire in the C101.
Baurluvva
Post Wed Aug 17, 2011 5:46 pm
Cheers mr moore! You are a bloody marvel. I'm leaving the autobox loom alone and giving your advice. Many thanks!!
