Hey up chaps, messing about with clutches on old 2002's - worked on me mates ones but reckon i've been sent a wrong clutch..
I need to know what the bolt circle diameter is on a standard 325i clutch pressure plate or the corresponding flywheel..
Easy to measure - just put a tape between the centres of 2 opposing holes on either the clutch or flywheel..
My flywheel is 265mm drilling but the new clutch is 260mm with no dowel location holes whatsoever...
The autofactors are being far from helpful!!
Ta
Hayelp! E30 325i clutch/flywheel bolt circle diameter
stimpy2002
Come on guys! I thought this was the E30 Zone
I'd have thought someone may have a clutch or flywheel kicking around in their garage just waiting to be measured!!!?
gooner1
- Out humping Reindeer
Give me 10 mins stimp and i'll get them for you.
gooner1
73 mms. Roughly. That's from the Flywheel btw.
