Just spent Saturday replacing the Touring tailgate seal, gas struts and the plastic cover that goes across the back.
All good but I made the mistake of pulling off the passenger side D pillar trim. Three of the six plastic tabs broke off and to remove the wierd metal clips from the pillar is beyond me.
Any one done this before?
Also how are the tailgate side strips attached to the rear tailgate screen?
are they bonded in some way.
Touring trim removal and replacement
- **BANNED**
D pillar trim slides off,either up or down,cannot remember which.
With the tabs broken off,you could try a silicone type glue such as Tiger Seal,or perhaps drilling a couple of small holes for black headed self tappers.
Youth is wasted on the young.
mark_i
Thanks Malcolm.
Not sure how to the slide the trim up or down because the plastic tabs completely fill the slots in the pillar.
But your idea of self tappers is good... i'll give that a go.
Anyone know about the method to correctly attach the side strips to the tailgate glass?
mark_i
HEEEEEEEELLLLLLPPPPPPP!
Now I,ve broken the tabs on the tailgate cover strip that covers the inside adjacent to the spoiler. Again... how to remove properly?
I am removing these parts to correctly route the rear washer tubing.
HairyScreech
think your best bet may be to get down the scrap yard and get some spare trim.
mark_i
Hmmm only problem is there's only 19 tourings in Oz... and none in the wreckers...
But lets imagine I did a spare, I have the same problem as with the clips that hold the D-pillar trim... they just dont want to come out
