Hello chaps,
After converting my 316 to manual, I had problems bleeding the clutch. Finally bled it but after a few days it would need bleeding again.
Changed the master, slave and piping and it seemed to work fine for a few weeks until I would find myself with no clutch on occasions and having to pump the clutch in order to change gear. This got progressively worse to the point where it has completely gone.
When pumping the clutch the fluid in the reservoir goes up and down. When comparing this to my brothers 325, the fluid doesn't move. There is obviously no resistance on the pedal but after a few pumps it suddenly becomes horrendously still but then disappears again.
I then cracked the nipple off the slave and pumped the clutch and fluid only drips out of the slave. I've since gone on holiday and left the slave open.
I am fairly sure its just a blockage but don't understand why it would get worse?
Anyone else got any ideas??
Thanks, Pete.
Funny clutch. Again.
Coops90
Malachite uber alles
m8782538
sounds like air in the system, could have gotten in via the slpit nipple on the slave. the slightest slpit and air will find its way in.
defjammin
how hard is it to convert auto to manual? i was thinking about doing this to my 316 but read a while ago it could cost up to 3k for the conversion
so that was crossed of my to-do list
Coops90
Fairly simple to do, just remember a few crucials.
I can't work outt why it would just be air. Surely when I cracked off the nipple, if air in the system was the problem, then after a few pumps fluid would he shooting out of the slave nipple and the level of fluid in the reservoir would have gone down?
