This is my first post because my e30 has been so reliable!
Got an 1989 325i, reassembled my engine after sending my head off for testing, skimming and valve seals being done and now it wont start.
When i have the pump relay removed the engine turns over as it should but when i put it back in engine turns over but keeps trying to stop as if there is too much compession or something.
Timing marks are all lined up, anyone any ideas?
HELP! E30 325 no start after new head gasket
e30andy123
- **BANNED**
So the engine is cranking but not starting?
Are you getting fuel/spark?
Youth is wasted on the young.
e30andy123
yeah got fuel and spark, its got to be a timing issue, i think although the timing marks are lined up i take it the cam pully can be a turn out? so i have swopped the ignition leads round and its now running but roughly, is it possible to have a car running properly with the cam pully a turn out and the plug leads swopped to the new firing pattern? so not to have to take the head off again ?
- **BANNED**
Two turns of the crank = one turn of the cam....
With both crank and cam 'on their marks',one turn of the crank puts the cam 180" out,second turn of the crank should bring 'em back into line.
Very odd!
Very odd!
FEP
Why would you need to remove the head to re-set the timing?
cliff_costa
You can not tern the cranck will the hed is at tdc you must bring both of tdc then remove the cam belt then rotat the came 180° reconict cam belt rotat engin slowley and jently by hand. Make shore timing marks alline
e30andy123
thanks for replys, after hours of head scatchin turns out the machine shop had re fitted the cam pulley wrong, i just assumed everything was correct and just alined the marks but that was way off tdc, also as the pulley wasnt located properly so the roter arm wasnt running true and snapped 4 elctrodes off my brand new cap! do you think they'll pay for a new one?
