Hiya guys, loving this place so far and have had a very warm welcome in the new members forum so i thought i'd ask for a bit of guidance with the little teething problems with my first e30!
On idle the revs dither a little and it seems to be over fuelling or possibly a slight blow on exhaust, is there any common factors of lumpy idles? was gonna do new sparks anyway which may well be all it is!
The only other bits that do my heaqd in are a few of the backlit LED's/bulbs have gone from the light switch panel and my little computer, they easy to replace or do i need new parts?
I've found the wiki about peeling badges but that aside i'm so impressed despite these petty little things!
Cheers in advance for your help
Rob
First E30, 320i teething problems
Motorhole
First ports of call for idle would be:
1) ICV. People remove these and clean them up with brake cleaner before refitting.
2) Check all your vacuum hoses for splits/air leaks.
Try to identify where the blow in your exhaust is coming from. It's not uncommon for the mainfold to blow on these, more often than not due to a snapped exhaust stud! Bloody fiddly job replacing on an M20 though.
e30Rob86
Cheers for that! Completely forgot about ICVs, had a few issues with these on our e36s, the guy I bought it from said some adjustments where made to pass the emissions on the MOT, any clue what they might of been??
The cars history has a job on the exhaust manifold from a few years back that involved new gaskets etc so think that should be ok, not done many miles since!!
AlpineCab
Easy job to do that makes a difference on an older car: IN addition to any other stuff you do, get a can of electrical contact cleaner and clean all the plugs within the engine loom that join up with various ancilliaries and sensors, clean the batery terminals, and the earth points.
AlpineCab
While i think of it, give the sensor that measures the crank position a clean as well. Its front of the engine, drivers side IIRC.
