Anybody have a good understand of our power steering system?
clydesdale
Post Thu Aug 04, 2011 1:24 pm
I am having odd symptoms. The car was off the road for 5 weeks and now it has periods where it does not want to re-center and the wheel is a little stiff. But, the key is in the morning the car steers and re-centers perfect. As I drive it the steering can get stiffer and it won't want to re-center properly. I replaced the rack 2 years ago and I checked the fluid and it is now Black. What might cause intermittent symptoms like this and why is it fine in the morning?
wullie325i
CAUTION - unreliable trader!
Post Thu Aug 04, 2011 1:26 pm
dont know why its fine early on but get the fluid flushed out from the lower pipe to get most of it out top it up bleed it and see where it is.
are the gaitors on the rack good?
clydesdale
Post Thu Aug 04, 2011 1:59 pm
Could you further explain how to flush the sytem? I was going to just suck out the reservoir and then refill a few times. The rack is 2 years old, but what are the gaitors? Thanks.
wullie325i
Post Thu Aug 04, 2011 2:40 pm
the gaitors are the black rubber bits on the ends of the rack they are kinda cone shaped and theres one on each end of the rack.
flushing it - if you follow the pipe from the reservoir down you will see theres pipes coming from the rack and the ends of these pipes are round with a bolt going through the middle, take the bolt out the nearest one and have a tub or bucket under it and remove it gently and dont bend or distort the pipe, the fluid will come out into the bucket and once it stops refit the pipe you removed top up the system leave the cap off the power steering reservoir start the car and turn the steering lock to lock a few times to bleed it check the level once its good put the cap back on and job done.
theres copper washers on the pipe and its best to replace them once you have had it off and these are a few pence from a motor factors. one on top one on the bottom
wullie325i
Post Thu Aug 04, 2011 2:41 pm
the gaitors should be sealed at each end with clips aswell so if theres none on any of them some jubilee clips or cable ties will suffice.
clydesdale
Post Thu Aug 04, 2011 2:53 pm
Ok, gaitors must be rack boots in the US. One of them was torn. I replaced it last week. The rack was not leaking and the shaft was still nice and shiney. There was the slightest amount of surface rust at the outermost end. I scuffed it up with 800 grit paper, just in that area. I then applied a small amount of grease to this area. I put the new boot on. The rack shaft looked fine, very clean, no leaks. It must have just torn recently.
As far as flushing- will it be the larger or smaller pipe?
e301988325i
Post Fri Aug 05, 2011 6:45 pm
Black fluid means it's overheated an is ruined, it's fine until the fluid gets hot. To flush the rack undo the high pressure feed to the rack and drain, do not run the engine until you have refilled. E30's need ATF Dexron II fluid, NOT PAS FLUID!!! If the symptons persist fit a PAS oil cooler in the return line from any vehicle, but I know an E46 item works nicely in front of the radiator and behind the kidney grills
I said:
e30topless said:
lock the wife in there
