auto to manual 325
cherryredbenj11
Post Wed Aug 03, 2011 3:17 pm
what do i need to convert a 325 auto to a manual. Obviously gearbox... etc
Post Wed Aug 03, 2011 4:28 pm
Pedal box
Gear lever and linkage mechanism ( Buy new lever & refurb linkage with new bushes etc before fitting )
Clutch slave & master cylinders, flexi hoses ( buy new ) & fluid reservoir
Those are the main bits - IIRC there is some sort of "inhibitor switch" that will need to be bypassed as well.
**BANNED**
Post Wed Aug 03, 2011 4:46 pm
In this photo;
the connector under the main lump of harness is a black/yellow going into a connector,then continues as black/yellow to the ign switch,the 'other' end goes to the starter motor....in the foreground,under the glovebox strap you can see a pair of black wires,I had just dis-connected those from that black/yellow,the blacks go to a relay mounted under the accessories socket(top left behind the glovebox),then out to the auto gear selector,where they plug into the selector.This entire sub-harness will need removing.At the gear selector socket,you should find a seperate two wire plug,this will re-connect to the short,two wire harness coming up via the gearlever gaiter from the reverse light switch.
When robbing the manual bits from your doner,do not forget to cut off the bracket that supports the clutch fluid thingy,it's mounted on the o/s inner wing....
Youth is wasted on the young.
cecotto479
Caution Unreliable Seller
Post Wed Aug 03, 2011 6:29 pm
Flywheel, clutch and spigot bush.
1981 E23 735i
Post Wed Aug 03, 2011 7:41 pm
Why cut off the Clutch fluid holder, it's a 10mm bolt you undo and the whole clamp comes away.
Post Wed Aug 03, 2011 8:11 pm
Rav335uk wrote:Why cut off the Clutch fluid holder, it's a 10mm bolt you undo and the whole clamp comes away.
Half of it comes away. Other half is welded to the turret.
Post Wed Aug 03, 2011 8:32 pm
Just checked my Auto, and the other half is there already welded to the turret. :D
**BANNED**
Post Wed Aug 03, 2011 9:04 pm
Perhaps it had a proper gearbox in an earlier life? :D
Post Wed Aug 03, 2011 10:13 pm
Nope, as far as i'm aware, it's always been an auto.
Billwill
Post Fri Aug 05, 2011 1:31 pm
cherryredbenj11 wrote:what do i need to convert a 325 auto to a manual. Obviously gearbox... etc
This conversion is done a lot here in SA...go to e30clubsa.co.za..there is a complete write up of what needs to be done. :)
Post Fri Aug 05, 2011 2:23 pm
Rav335uk wrote:Nope, as far as i'm aware, it's always been an auto.
It's not present on any of the auto saloons and tourings I have, and not present on any LH drive car at all. Don't have any RH drive auto cabs, so can't speak for those.
penton08
Post Fri Aug 05, 2011 5:33 pm
The last 3 cars i have converted to manual have all had it there ready. Left hand drive cars use the brake reservoir for the clutch i think.
Post Fri Aug 05, 2011 5:43 pm
you need the metal clutch fluid pipe than runs across the bulkhead between clutch master and clutch slave also
mark_i
Post Sat Aug 06, 2011 11:59 pm
and the correct length propshaft... plus a diff with a decent ratio
