The gearbox in my car (86' 325i) feels a bit rubbish, gear change is clonky and sloppy and selector can be moved up and down whilst in gear. Are there bushes i should check and are they easy to access? Also what can i do in terms of a short shift and are they hard to find/fit?
Adam
Slushy Gearbox
Adams-Sideways
Yes. The linkage mechanism can be completely re-bushed - its a pig of a job if you don't have a lift and are doing it on the floor with the car on axle stands.
The bits to do it arent that expensive its just dirty fiddly work.
There is also quite a bit of stripping to do before you can actually get at the linkage - the exhaust, heatshield and prop all have to come off - and its when you start factoring in things like new propshaft guibo, centre bearing and gearbox mounts ( all of which WILL be fooked if theyve never been replaced ) that it starts getting expensive.
You can buy a replacement lower gearlever section for about £15 - the popular Z3 levers which give a shorter shift I think are still out of stock and are considerably more expensive.
Once the linkage is rebuilt and there is no sloppiness in the shift the standard setup is excellent anyway IMO
Check my resto thread in the pics section for some info on rebuilding the linkage.
It is a LOT of work to do it properly - however the results are worth it.
Good luck
Good luck
http://www.e30zone.net/modules.php?name ... &start=125
From about 1/3 of the way down.
I can give you a list of all the bits you need to do it properly.
Adams-Sideways
Very helpful answers thankyou, read your thread too, fantastic stuff
