Please can someone help me.
My battery died on Thursday after car was standing for 10 days. I got it jump started, drove for an hour and when I started it again on Saturday, it was dead.
I left it and got it jumped again today and drove for another hour. As soon as I arrived back, I turned it off and started it again after only 2-3 minutes and the engine would not turn. I think the battery was charged though.
The funny thing is that when I then wiggled the +ve wire off the battery and put it on again, creating a little spark, and start the car, it starts again perfectly.
Does anyone know what could be wrong and what I can do about it?
Battery problem
Take it to an independent car spares shop and get them to check it - most have a tester which will reveal if it has any dead cells.
Although it sounds like you may have a loose connection somewhere.
If all the connections are good it does sound like the battery is on its way out.
I had a similar incident about 18 months ago where it was fine one day and then dead the next - the car would go off a bump start and drive fine but as soon as you switched the engine off and went to restart it was dead.
How old is the battery ?
dr007
Battery looks fairly new, I have only had the car a couple months though so not sure.
The funny thing is that fact that to get it started again I take off and reattach the +ve wire to the battery.
This started happening after I cleaned the engine bay so I may have loosened something or got something wet I guess...
Check all the earthing points - battery to body and in particular body to engine ( there may be 2 or 3 different ones ) remove the cables, clean the connections with wet & dry paper and put vaseline or grease on the in reassembly.
Definately get the battery tested though - some ( especially cheap ones ) dont last long.
