Could somebody confirm what colour the rubber part is
on genuine BMW seals. Have some from ECP that came with a
Elring gasket set that are Red, have some from another Zoner that are Green.
Valve Stem Oil Seals
gooner1
- Out humping Reindeer
- **BANNED**
Bet some-one has some amber ones....
Only seen green,myself,and they were in an Elring set.
Wild guess would suggset that red is the new green!
You have got some of the little 'condom' thingys that you slip over the valve stem to protect the new seal?
Youth is wasted on the young.
OEM are red.
gooner1
[quote="daimlerman"
You have got some of the little 'condom' thingys that you slip over the valve stem to protect the new seal?[/quote]
You jest but that are important Rob.
Put the valve in, slip the condom thing over and then place the seal over that and down the stem.
The sleeve saves the seal lip meeting the collet grooves on the way down which in turn could damage the lip.
gooner1
No mate, i was genuinely confused, no sign of any protective type of cover
in the pack of seals i have. Are they supposed to come with them?
They do in OEM from the dealers. little orange plastic sleeves.
I may have a spare here if you need one that I can stick in an envelope and forward on?
gooner1
Cheers Trev, i may just take the Head back to the Machine shop
and get them to replace them. It is after all what i asked them to do
in the first place, along with pressure test and reface.
Really can't understand why they carried out all the work, including additional free work
for taking so long, then leave the old seals in.
let me know if you do need one. I should be able to sort.
gooner1
Will do mate, offer is very much appreciated.B7 wrote:let me know if you do need one. I should be able to sort.
