Differential issues 325i sport
Josw
Post Wed May 04, 2011 7:41 pm
Hello
I have an issue with my f reg 325i sport and i am after some advice please.
I booked the car in to a garage to have a rear wheel bearing replaced. Th car is making a grinding noise which comes and goes, it sounds very dry. The mechanic has told me that he thinks it is the differential. Is there a way of checking this to be certain? Would it be ok to use the car whilst sourcing a diff? It has come as a shock to me since the car is never driven hard. Would it be worth rebuilding the diff? JP race at Silverstone?
If anyone has a diff for sale, pm me.
All help is much appreciated.
town325i
Post Wed May 04, 2011 7:42 pm
If you want the diff rebuilding speak to gareth on here he does them at a good price
Josw
Post Wed May 04, 2011 8:40 pm
Thanks, what is his username
Post Wed May 04, 2011 9:20 pm
Josw wrote:Thanks, what is his username
Eh, gareth!
Very few 20+ year old LSD's will not be in need of a rebuild by now. Most are probably largely expensive ornaments, with little different from an open diff.
Good ones will make strange noises if the wrong oil is used in them.
drocha
Post Fri Jul 29, 2011 1:44 pm
brian, how come even a good one will make strange noises if the wrong oil is put in? mine doesn't 'whine', it's more of a metallic rubbing noise.
i saw that you'd also mention oil type in a previous post. i got all the fluids changed after I first bought the car, but i'm not sure what type was used. could this really be it? i'm worried about spending money replacing my diff with another used one, which may also be just as knackered as mine.
other diff post: http://www.e30zone.net/modules.php?name ... ff+rebuild
thanks.
Barx325i
Post Fri Jul 29, 2011 2:00 pm
well, I have what has to be the worlds best 20yr old slippy diff
It's originally from a low mileage auto and doesn't make a sound, it locks up absolutely as it should, it's a true pleasure to pull out of any junction.
I changed the oil around 3 months ago and the existing fluid came out almost crystal clear, I was slightly annoyed spending money on new LSD oil, but hey ho it went in
It's a 3.73 and is for sale so if you feel you want a replacement it's here.
Gareth does a fine refurb job, he can alter your ramp angle, increase the number of clutch plates etc. he is the man for the job, but just letting you know I have a truly fine example here.
