Just a quickie, has anyone done this without any adverse effects. The car is for track use only and won't be used in cold temps. I've got two broken thermostat housings, where the inlet for the pipe coming from the throttle body has corroded so badly it's no use. So I either press a new piece of 10mm pipe into the thermo housing or remove completely the whole set up from the top of the block forwards and blank off the broken hole into the thermo housing.
Assuming the set up is there to prevent carb icing, which should be OK, but I'm just checking there are no problems with no longer having water circulating from the top of the block.
Any thoughts would be appreciated.
Nick Hine
M20 Throttle Body heater pipe delete - has anyone done this?
Cloggy Saint
Ajsingh
i have blocked off the coolant from going around the throttle body in my 2.7.. and im sure a few others on here have done the same.... has caused me no issues!
E30 Crazy!
- **BANNED**
Me too,but I ran a pipe direct from the thermostat housing to the back of the block,'just in case' I was interfering with water circulation!
Youth is wasted on the young.
m_jermyn
No issues for me either
nickphine
Ta chaps, I've gone the whole hog and blocked off the block outlet too as I figured that water comes out the back of the head anyway and it's a fairly short route from one to the other.
Now I'm tempted to block off the breather recirculater thingy and just use a catch tank too.
m_jermyn
If you block of the breather then the crank case pressures will blow the gaskets and seals out.nickphine wrote:
You can as you say fit a catch tank and then vent that back to the throttle body as I have done.
If you fit a catch tank then a breather on the tank venting to atmosphere you will create a air leak and the car wont run properly
Barx325i
anyone of the opinion this is a decent mod (TB heater pipes delete), not just a broken-stuff bodge?
