If you have a pre face car with blanks in the front valance and a set of retro fit fogs, how do I fix them up? Should I have mounting points because I don't appear to?
Are they different?
pre face front valance question?
Duke137
IIRC there are two types of pre facelift front valance and two types of foglight mounting bracket. One type mounts to the valance and the other to the flitch panel under the washer bottle/ abs pump.
Duke137
Cool thanks Pete, might need a new valance later down the line for a fog light retro fit.pacerpete wrote:IIRC there are two types of pre facelift front valance and two types of foglight mounting bracket. One type mounts to the valance and the other to the flitch panel under the washer bottle/ abs pump.
Correct - they changed I think from the '85 to '86 model year from C Reg has the later valance which is also has a different lower lip/airdam.pacerpete wrote:IIRC there are two types of pre facelift front valance and two types of foglight mounting bracket. One type mounts to the valance and the other to the flitch panel under the washer bottle/ abs pump.
Duke137
Mine is 85 "C" so do I need a newer one to retro fit fogs?
Yours must have been an early car registered late - thats an earlier valance
I've seen earlier cars with the fogs fitted so it must be possible with the correct brackets without swapping the valance over
Duke137
Cheers Rob, will need to think if I can be bothered for the sake of fogs
PS what a sorry turd
